BMW Z4 M Coupé Motorsport Version
02-28-2006, 06:00 PM | #1 |
Rep 469
BMW Z4 M Coupé as motor racing kit.
Press release, 02/28/2006 The first BMW two-seater for Nordschleife fans and international customer teams. Munich/Geneva, 27th February 2006. Unveiling in Geneva: On the occasion of the Automobilsalon, Prof Dr Burkhard Göschel, BMW Group Board Member Purchasing and Development, introduced a new racing car for customer motor racing. The Motorsport Version of the BMW Z4 M Coupé, which has already made a big impression as a production model, is the first two-seater BMW Motorsport offers for customer teams. When it came to the development, BMW faced a huge challenge: The car had to have what is needed to race successfully on the world's most demanding and spectacular racetrack, the Nürburgring's famous Nordschleife. The new motorsport coupé can be used by private BMW customer teams in the German Endurance Championship and in the Nürburgring 24-Hour Race. The power unit of the beefy coupe is a BMW Motorsport designed 3.2-litre in-line 6-cylinder engine delivering about 400bhp, with the suspension area in particular benefiting from the knowledge gained from the successful BMW M3 GTR project. With its varied component ranges, BMW Motorsport and BMW Racing Parts Distribution offer customer teams a new technology platform for use in many miscellaneous international racing and club sport series, with the Nordschleife enthusiasts not being the only interested party, as the brawny coupe also represents the perfect car for use in the Belgian Belcar series and other, non-European, endurance series. The kit can be ordered from May 2006 at BMW Motorsport and will be available for an estimated € 250,000 (plus VAT). Technical Data BMW Z4 M Coupé Motorsport Version Length: 4415 mm Width: 1880 mm Wheelbase: 2493 mm Front & Rear Overhang: 865 mm/774mm Rear Wing Width: 1504 mm Front & Rear Ground Clearance: 80 mm/90 mm Front & Rear Tyres: Michelin 27/65-18, 28/71-18 Front Brake: Grey cast iron disc dia. 380 mm / 6 pot fixed calliper Rear Brake: Grey cast iron disc dia. 320 mm / 4 pot fixed calliper Drive Line: sequential 6-speed gearbox, sintered clutch Engine Layout: six cylinder in line Cylinder Capacity: 3246 cc Bore x Stroke: 87 x 91 mm Compression Ratio: 12,5:1 Max. Power: approx. 400 PS at 8200 rpm Max. Torque: approx. 400 Nm at approx. 5750 rpm Max. Revolutions per minute: 8400 rpm Cylinder block: one-piece construction Crankshaft: forged steel part Piston: forged slipper skirt piston Con-rod: Steel Cylinder head: Aluminium, four valves per cylinder Valve train: Two chain driven overhead camshafts with variable valve timing Intake System: Six single throttle valves, Carbon fibre Air box with resonance induction optimised inlet pipes Exhaust System: Multiple pipe manifold with silencer and catalytic converter Lubricating System: Wet Sump Lubrication Cooling System: Water / Air cooler Flywheel: Steel Fuel System: Inlet-Pipe Injection, one Injector per Cylinder, 5 bar injection pressure Fuel: 5-star lead-free petrol, ROZ min=98 Fuel Tank Volume: 120 litres Minimum Weight: 1200 kg in Nürburgring Specification Engine Management System: BMW Motorsport ECU406 with two powerful microprocessors, Ethernet Interface and four CAN busses; Cylinder selective optimized Injection and Ignition; Pit-Speed-Limiter; Quick-Shift; Engine Log Book; Electronic Throttle Control; VANOS Control; Race ABS; Traction Control. Energy Management: Distribution and Control of the electric energy through the BMW Motorsport POWER400 Control Unit; Networking of all Sensors and Actuators through a CAN Bus. Electric loom: Weight optimised Ignition coils: Six high performance pencil-type ignition coils with integrated ignition driver. Sparkplugs: NGK high performance Sparkplugs Instruments: Free programmable LCD Display with integrated shift lights Steering-wheel: multiple function Steering-wheel with Quick-Release mechanism and display control |
02-28-2006, 07:01 PM | #4 |
missing two turbos.
577
Rep 4,859
Drives: fast around corners.
Which airport is that thing headed to?
06 AW E90 330i ZPP/ZSP/Step/Expired Warranty : Prior Design Front : ACS Rear : ACS Roof : BlackLines : Simota Intake : Carbon Fiber Interior Trim : : MTEC V3 : 24% Charcoal : V1 Hardwired : Solaris Invisibulbs/LED interior : |
02-28-2006, 07:31 PM | #6 |
198
Rep 2,485
That is awesome. Absolutely awesome. I want a poster.
Mind you, there's a kid in a Civic around here with a bigger wing.
2006 E90 330i (retired)
2009 E90 335i (retired) 2012 E70 X5 50i M Sport (retired) 2016 F10 535i M Sport |
02-28-2006, 07:50 PM | #7 |
172
Rep 160
Am I the only one who doesn't like it? I don't relaly know anything about cars, but I don't think it looks nice. It looks unpropportional. The nose is way too large and closing it with a roof accents the huge nose more, IMO. I don't think it's cute, at all.
02-28-2006, 07:58 PM | #8 |
52
Rep 1,024
Sorry Kat, I think it looks fantastic. I will qualify that though. I don't think I'd drive something that looks like that around town. I prefer something with a bit more class for a car I'd drive every day BUT, For an aggressive race track only z4...
330i Monaco Blue, Terra /w aluminum trim, SP, PP, CA, PDC, Nav, Folding Seats, Sat Prep European Delivery Blog Picture Gallery |
02-28-2006, 08:04 PM | #9 | |
172
Rep 160
*wow, the word IMAGINING has a lot of ingingingings, it made me all confused. i had to read it over like, 3times. |
02-28-2006, 08:35 PM | #10 |
33
Rep 1,770
Will new Z4 have the steel top just like the upcoming 335i coupe?
2006 330i Steptronic/Alpine White/Black Leather/Burl Walnut Trim/Premium Package/iDrive/Heated Seats/Winter: STYLE 159 Blizzak LM-22 RFT/Summer: TBD
2004 X5 Steptronic/Alpine White/Grey Leather/Poplar Trim/Premium Package/Heated Seats/iPod Adapter |
02-28-2006, 08:38 PM | #11 |
Chicketeh china the chinese chicken, you have?
34
Rep 790
Drives: 335ci hold out
I hate the Z4's headlights! thanks for the pix
"In Soviet Russia car forks you!"
02-28-2006, 09:58 PM | #12 |
Moderator
497
Rep 27,441
siiik! thanks for the pics!
02-28-2006, 10:11 PM | #14 |
~*teehee*~
95
Rep 28
Drives: Clownshoe and a 4x4
Holy god damn
02-28-2006, 11:53 PM | #15 |
160
Rep 5,271
Shit!!!!!!! THEY are Awesome!!!!1
2006 330i | Black Sapphire Metallic | Step Auto | Navi with iDr | Sports Pkg |OEM Rear Spoiler | 3M CS35 Tint | H&R Sport Springs | Koni Yellows | Advan RS Racing Hypersilver: 19x9 et22 19x10 et20
03-01-2006, 01:39 AM | #17 | |
~*teehee*~
95
Rep 28
03-01-2006, 01:59 AM | #19 |
33
Rep 1,770
Could someone be able to answer my question? Will it be a steel top like the upcoming E92? One of my friends wants to get a 3.0i Z4 in the summer..
03-01-2006, 04:35 AM | #20 | |
21
Rep 1,002
That shows you have no idea of what´s going on with the Z4. The upcoming E93 convertible will be a true convertible with a retractable steel top. The E92 you mention is the coupe, naturally with a steel roof, what else. The Z4 will continue as a regular roadster with a soft top just like before. Addintionally there will be a Z4 coupe that, as the name allready gives away is NOT a convertible. It´s a fixed (steel of course what else) top coupe. NOT retractable thus very much NOT like the E93. Instead of nagging for an answer around here, why not simply look at all the available pictures of the facelifted Z4 roadster and the new Z4 coupe. It´s very obvious really.
No, not THAT kind of tierfreund!
03-01-2006, 06:10 AM | #22 |
241
Rep 2,059
Thanks for the pics, they look great! I like this cool shot of the rear.
330i 6MT l 255 HP @ 5900 rpm 214 lb-ft Torque @ 3500 rpm l Alpine White l Beige l Aluminum l ZSP l 494 l PDC
"Freude am Fahren" = "Joy to Drive" |
