03-07-2019, 08:08 AM | #177 | ||
178
Rep 1,432
2018 F80 LCI II ZCP ///M3 Mineral White M-DCT| Sakhir Orange Interior| |M Performance Exhaust| |
05-11-2019, 09:07 AM | #178 |
Christmas Poo
1065
Rep 1,195
Took me a while but here are the settings for my 2018 HK system. I listen mostly to rock and think the bass/midrange settings are pretty solid. Treble on this might seem a bit high for some but I think my sensitivity for treble is a bit low due to years of competition stereo systems... V=IR bitches!
Ideally logic 7 or "surround" should be off so you get better Left - Right sound staging, but the stock speakers in this car are middle of the road and slightly under powered so it just sounds better to me with it turned on...it needs that +3 dB with that extra center speaker on...I'm more into the dynamics of the car than radios at this point in my life but I will say the 2018 iteration of the HK stereo is leaps and bounds better than the 2015 HK stereo, so I'm pretty happy with it (years of me swapping out monitors and adding amps are done!).This is tuned by my ear, and while driving the car (MPE so my interior is noisy, ASD programmed off)...If you're sitting there with the engine off this will sound a bit flat/odd, but this is what sounds good to my ear while actually driving. Again, you may just need to turn the treble down if you are young, or took care of your ears...Hopefully this helps someone out!
06-06-2020, 02:42 PM | #179 | |
29
Rep 90
06-06-2020, 05:25 PM | #180 | |
2712
Rep 2,371
Much better than bluetooth.
2015 Black Sapphire Metallic 6MT M4
06-07-2020, 07:02 PM | #181 |
29
Rep 90
11-16-2020, 10:13 AM | #182 |
3633
Rep 1,397
A question I can’t seem to find the answer to:
I see bavsound advertises their subs as plug and play, however, earlier in the thread it was stated do not use less than 7.2 ohm subs as this will add strain to the factory HK amp. What gives? Are they applicable to my f82 with factory HK? |
