11-25-2014, 06:21 AM | #45 | |
38
Rep 164
TIA. |
11-25-2014, 06:36 AM | #46 |
137
Rep 372
Its under the BMW widgets. It takes a second for them to load.
M4 - White Sex Panther
E46 M3 - Pablo the cocaine smuggling donkey |
11-25-2014, 12:32 PM | #48 |
47
Rep 79
I use software called Room Equalization Wizard (REW) with a calibrated USB mic to tune my home theater system. I have been meaning to try and apply the same principles to tune the audio in the new M4, but haven't had the time yet. My expectation is that there will be a combination of EQ settings that produces the flattest response. Whether that results in good, or even acceptable, sound is yet to be seen.
I have only had the M4 since Thursday, and I am still struggling with the challenging iPhone integration, so I haven't paid much attention to sound quality. My initial impression is that the level of bass is much softer that I had in my 335i premium sound system. So, does anyone have a theory why we are disappointed in the sound system? Is it the electronics, or the speakers? What are some suggestions to improve it? |
11-25-2014, 02:05 PM | #49 |
2712
Rep 2,371
Huh. You all must have some really sensitive ears, because, while I don't think the HK's sound great, they don't sound terrible. And I say that having come from a $5k+ sound system in my last car, with bi-amped Boston Acoustics up front, tuned for high sound quality.
2015 Black Sapphire Metallic 6MT M4
11-25-2014, 04:29 PM | #50 | |
555
Rep 2,633
11-27-2014, 12:36 PM | #51 |
47
Rep 79
I spent some time this morning using the Room Equalization Software (REW) and a calibrated microphone to analyze the frequency response in the M4's cabin, and to tweak the equalizer settings to try and flatten the response.
For those of you not familiar with REW, it is a shareware audio measurement system that runs on a laptop. It uses a calibrated USB microphone as input, and outputs test tones over a 3.5mm stereo cable plugged into the BMW's AUX IN audio port in the console. REW sends user-definable frequency sweeps to the vehicle's audio system, which are then picked up by the mic, and displayed as a response graph on the PC. I took care to place the measurement mic at exactly the spot where my ears are (27" above the driver's seat, and approximately 7" forward from the seatback). I sat in the passenger's seat, closed all doors, and rolled up the windows in order to simulate a typical driving condition. I started by turning Logic 7 off, and centering all the tone controls to their flat positions. A "reference" measurement was taken with these settings. I then conducted a series of measurements while adjusting each of the frequency band sliders to different positions in order to get a feel for how the various sliders affected overall frequency response. Finally, after the familiarization phase, I started zeroing in on slider settings that produced the "best" response (in my opinion, of course). The following graph shows the beginning "reference" response, and the ending "optimized" response, which also has Logic 7 turned back on. The first thing you will notice is that the two measurement curves are not very different. On the positive side, this means that the audio system is reasonably tuned for the vehicle in its flat settings, but on the down side, it means that the frequency sliders are only marginally effective in altering the sound characteristics. Here are the settings I used: 100Hz +4 200Hz +7 500Hz +0 1Khz +4 2Khz +5 5Khz +5 10Khz +5 I then played some familiar music CD's to assess the results. In general, I was reasonably pleased with the sound of the system. It sounds a little less bass-heavy than I was used to in my 335i, but I think it is just a matter of getting used to a different system. Unlike other opinions I have seen in this forum, I don't think the H-K audio system is a disappointment. If you try the settings I posted, I would enjoy your feedback. Remember, audio is highly subjective, so experiment! |
Lerxst M4142.00 |
11-27-2014, 01:25 PM | #52 | |
13
Rep 163
11-27-2014, 01:32 PM | #53 |
143
Rep 320
Thanks for doing this. However, some of it doesn't really make sense.
Your settings show you have significantly boosted low freq 100 and 200hz, yet the black trace shows these significantly below the "flat" blue trace. Likewise the high frequency 10khz. The boosted mid range 1-2khz does seem higher Am I reading this correctly, blue is flat, black is with the eq adjustments? |
11-27-2014, 03:11 PM | #54 | |
47
Rep 79
01-06-2015, 04:05 PM | #56 |
70
Rep 291
I've been tweaking my EQ since I got the car in October. I haven't been happy with it at all... until this morning, when I hit upon this nutty config:
(shitty pic alert) Call me crazy, but I need my awesome sound, going on 30 years now, and this seems to work. Decent punch and balance. I may slightly tweak it still, but this is very close. For my ears, anyway. Say what you will about Logic 7. Cars provide such a shitty environment that I don't mind the wraparound effect. Does it reflect the original stereo staging? No. Do I care? No.
F80 6MT. In full color.
01-07-2015, 09:59 AM | #57 |
658
Rep 1,749
Gus any settings boosted that much make no sense. Your looking to get a sound out of a system that is impossible. This system is like last individual sound on m3, needs loud volume to sound good. Cut 200 frequency by 2 or 3 clicks. Cut treble by 1 click, boost bass by 1. Logic 7 off. And crank it up. That's as good as it gets.
These huge boosts and fader to rear and big bass boosts just are silly. Whatever equupment your using to reach these conclusions is not being used properly |
01-07-2015, 11:33 AM | #58 | |
137
Rep 372
Saying that HK is shit and even taking the time to post your little throw up face is just a bit overdone no? If you are such an audio buff, then you probably should have spent some time at the dealership testing out the HK system before ordering or purchasing your car. This would have saved you some cash and some posting time. Now, for those of us with a unseasoned audio ear, I am still interested in seeing settings and how the settings were chosen so that I can continue to ENJOY my purchase and possibly make it even better.
E46 M3 - Pablo the cocaine smuggling donkey Last edited by cctm4me; 01-07-2015 at 11:40 AM.. |
01-07-2015, 03:56 PM | #59 | |
37
Rep 108
2019 BMW X4 m40d
01-07-2015, 04:17 PM | #60 | |
1385
Rep 3,834
Man, I wish BavSound would pay me. I've been telling everyone how great my BavSound is. Photo below should give you a perspective of BMW OEM F80 speakers vs BavSound. |
01-07-2015, 05:10 PM | #61 | ||
24k GOLD
148
Rep 1,453
01-07-2015, 09:33 PM | #62 | |
1385
Rep 3,834
http://f80.bimmerpost.com/forums/sho....php?t=1061790 |
01-08-2015, 01:18 PM | #63 |
70
Rep 291
Cool. I have tweaked it a little. I boosted the 500 by one click, and boosted every one 1k and up by one click each. But, so far, this setup is holding up nicely.
01-22-2015, 04:07 PM | #64 |
48
Rep 122
01-22-2015, 09:35 PM | #66 |
70
Rep 291
Real cool, man.
