03-22-2024, 03:46 PM | #23 |
1154
Rep 624
03-23-2024, 03:34 AM | #24 | |
168
Rep 222
I always thought M Sport discs were 340mm regardless of engine size, unless you spec’d the M Performance brakes and then these came with 370mm discs. I’m gonna physically check today to see what size discs I have.
2016 BMW 335d M Sport xDrive Touring
03-23-2024, 03:49 AM | #25 | |
1154
Rep 624
If your car is a 35d and has factory fitted blue M Sport brakes, it will have 370mm front and 345mm rear. The M Performance calipers you mention are 370 units, but were only available as a dealer fit accessory (not factory fitted) and came in either Red, Orange or Phoenix Yellow. |
03-23-2024, 04:46 AM | #26 | |
168
Rep 222
blau3er1154.00 |
04-18-2024, 02:41 PM | #28 |
168
Rep 222
Quick update: After weeks of researching the best prices of 370mm front discs, I stumbled across a private seller on eBay with a pair of reasonably priced Brembo grooved/dimpled 370mm discs.
Suspect they are the same as the OEM M Performance discs as they look identical. As for pads, I can’t seem to find the Ate ceramic pads for the fronts, just the originals. BMW genuines are £130, as are the Brembo Xtra’s. Any recommendations for daily/fast road use to suit the Brembo grooved/dimpled discs?
danb19791953.50 |
04-18-2024, 03:59 PM | #29 | |
Idiotic lifter of heavy stones...
1954
Rep 2,133
Drives: 2015 F31 325D M Sport touring
IIRC the 340mm and 370mm calipers share the same pads If not those then the Brembo HP2000s seem to get good reviews I've stuck with OEM BMW and TBH they've been superb; great braking, quiet, not very dusty and have performed from some very hard/fast driving to dead stops with zero issues https://www.ebay.co.uk/itm/265167767...Bk9SR7CEhbDeYw
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
Jon TDI168.00 |
04-19-2024, 02:39 AM | #30 |
829
Rep 1,060
OEM Jurid pads. They are quiet and bite very well from cold. Very dusty, but it comes off easily and doesn't attack the clear coat like a lot of aggressive fast road pads do.
05-03-2024, 10:09 AM | #31 |
168
Rep 222
Starting to build up the parts required for disc & pad replacement.
Gone for full on Brembo. Got the matching rear discs, just waiting for HP2000 rear pads.
danb19791953.50 |
05-03-2024, 10:36 AM | #32 |
1954
Rep 2,133
If not already; worth spending another £100 and getting HEL braided lines IMO
Jon TDI168.00 |
05-03-2024, 10:59 AM | #33 |
829
Rep 1,060
Nice! That little lot should work well as a package with the Brembo calipers
What are the dimples for? I've seen holes and grooves before, but dimples! |
05-03-2024, 11:57 AM | #34 | |
1954
Rep 2,133
Exactly same design as the BMW discs
Jon TDI168.00 |
