      05-11-2010, 04:47 PM   #1
akariz
Drives: BMW 120D Sport
[120D Sport] Hand brake light on dash stays lit
Hi all;
i was trying to test how i reset the lights after service following post found in forum, it was working good but when i try to reset rear brake, that is one after i punched reset button it was not working, milage displays 00000000 and instead of red is now changed to yellow color, same for rear.
Later when i turn off then turning engine on a red ligh for hand brake show in the dash board please any advice to remove the red light hand brake???
In addition to above in service menu the following are also showing red ever since:
MOT lights
Vehicle Check (car in ramp) this shows red on dash after i remove keyfob from egnition.
However on menu servvice this is showing as 30000 till next service is due?
Anyone had or experience this problem and is there any solution not involving going to BMW?
thank you
      01-06-2013, 08:22 PM   #2
SnaKe0001
Drives: BMW 128I 2009
Originally Posted by akariz View Post
Hi all;
MOT lights
However on menu service this is showing as 30000 till next service is due?
thank you
I have the exact same problem with my 128i 2009...
I would like to know what you did to repair this problem?
You chaged the pad + sensor ?
Can you delete this error without changing sensor ?
Thank you so much :-)
Marc
1addicts
