M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Vague clutch engagment
      01-27-2024, 12:14 PM   #1
ricko32
20
Drives: F87 M2C
Recently I read a review of an M3 on Motor1.com by Chris Perkins. In this review, he states the manual 6-speed is not the greatest.
" I wish I didn’t feel so conflicted about the manual transmission. The six-speed makes this car more engaging, for sure, and I’m so glad it’s available as an option, but it’s just not a great gearbox in every scenario. Clutch engagement feels vague and the throttle calibration and gearing are such that it’s difficult to get off to a smooth start and quickly execute a clean 1-2 upshift in succession"
I have been driving a stick for many many years and would have to say I agree with this statement in my 2020 M2c. Kind of disappointing.
      01-30-2024, 10:24 AM   #2
philth
philth's Avatar
199
Drives: F87 N55
      02-09-2024, 09:22 AM   #3
Enabled
1410
Drives: 328xd Wagon, M2 Competition
Pretty much true.
Remove the clutch delay valve, flush the clutch fluid, install a rear shifter bushing (such as the Turner one), and then get a tune that modifies the throttle control.
I make a very specific tune for the S55 that manages the throttle control a lot better and more linear, removes revhang, and helps with some of the shifting.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
chris7197334.00
      02-09-2024, 10:19 AM   #4
maxcbrdriver
168
Drives: 2010 BMW 535xiT; 2021 BMW M2C
Between the CDV delete and the AS SSK, I feel that my 1-2 shift is pretty smooth. Not sure which of those parts contributed the most as I installed together, but the overall shift feeling is significantly better. As I understand it, the "modifications" that Toyota did for the Supra 6mt are basically just changes to the linkages and bushings and all of a sudden it's great, but those changes are what the AS SSK also does.
Appreciate 2
Enabled1410.00
chris7197334.00
      02-13-2024, 05:45 PM   #5
chris719
7334
Drives: '08 M Roadster
It's hard to say what they did, because the Supra and Z4 now have a completely different transmission from F8x and G8x. It also can handle more torque. I wonder if it will ever surface in the G8x. I mean, it's a different part number and derived from the 6 speed that was in the base Z4, not from the GS6-45BZ. I'm sure it shares a lot of parts but it is different.
      02-13-2024, 05:49 PM   #6
chris719
7334
It's not wrong, but this car is buttery smooth compared to a Z4M in terms of shifting when cruising around town. Drive one of those, if you're not perfect it's one of the jerkiest experiences you'll ever have.
gnx759.50
      03-01-2024, 02:13 PM   #7
pt8o
12
Drives: M2C
CDV is a must on the M2, was quite annoying shifting before the mod.
Definitely also recommend either AS SSK or a solid mount shifter, ECS Trans mounts.
Funny enough, the shoes I wear make a difference too - I find it hard to drive wearing runners, so I usually only wear chucks when driving
chris7197334.00
      03-01-2024, 03:24 PM   #8
chris719
7334
Originally Posted by Enabled View Post
Pretty much true.
Do you also do S58 if unlocked by Femto first?
m2
