BMW 2 Series Gran Coupe Forum (F44) BMW 2 Series Gran Coupe (F44) General Discussion
      07-11-2023, 06:50 PM   #1
cv2002
Drives: 228i Gran Coupe
Cabin air filter replacement
Hi
Has anyone replaced the cabin air filter in a 228i Gran Coupe? I can get the parts - seems like something I should be able to do pretty easily, but I have no idea where the filter is. Used to be easy on my E46. TIA and sorry if this has been covered. Nothing turned up in a forum search, Youtube or google.
      07-11-2023, 07:30 PM   #2
schnell325
Bored at work....
schnell325's Avatar
890
Drives: 2016 F82 M4 GTS//2022 M235iGC
My guess is through the glove box?!?
But I’d definitely like to know the answer too
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD!
Anti Matter :2016 F82 M4 GTS
What next?!? A 2022 M235i GC- I must be getting old
      07-12-2023, 01:40 AM   #3
cjn
99
Drives: 2021 F40 M135iX
Here are the instructions for the F40. Probably OK for other F4x models.
Appreciate 2
YogiPL15.00
      07-12-2023, 04:50 AM   #4
YogiPL
YogiPL's Avatar
Poland
15
Drives: BMW F44 220i
I did it on mine and the instructions above are correct.
It's not hard, it's just a pain in the ass to get to since you have to dive under the glovebox to do it.
      07-12-2023, 05:29 AM   #5
cv2002
Thanks all!
I appreciate the help and response. Was a bit shocked at how hard it was to find this info.
      03-10-2024, 12:05 PM   #6
Z-_Hamza_-Z
Drives: BMW F44
Hello i tried to use this gudie on my 2021 Bmw Gran Coupe but i cant seem to find the pollen filter.
i have took both covers off but my cabin area looks diffrent. can any one help me
      03-10-2024, 02:16 PM   #7
YogiPL
YogiPL's Avatar
Poland
15
Maybe pictures will help. Check attachments.
01 - general view of the area where the filters are, you need to really dive under the glovebox...
First remove the panel below the glovebox, there are two tabs you need to turn by 90 degrees and the panel should just fall down.
Second remove the single screw holding the second panel, pull from the front and it should come off easily
02 - once you remove both panels as described in 01, this is how it should look like
Once you're there just open the filter cover, pull out two old filters and put new ones in the same orientation (observe airflow direction marked on the ones you remove)
03 - close up of the filter door and hole
Hope it helps!
      03-10-2024, 05:28 PM   #8
Z-_Hamza_-Z
Drives: BMW F44
Hope it helps!
Thanks for you photos and tips but my cabin area looks different i will takes some photos tomorrow
I figured it out i have a right hand drive car so the pollen filter is located in the driver side so had to unscrew the centre console cover and change the filters thanks for you help
