M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Broken shift Rod
      05-09-2023, 03:03 AM   #45
chris719
7334
Drives: '08 M Roadster
Originally Posted by doughboy View Post
It's the same shift rod used on all M2 and M2 comp and F80 m3 and m4 OG and LCI since 2014.
Real oem only goes to 2019, but I'm sure it's still in use as it shows on other parts sites.
Not heard any problems on M3 forums??
Maybe the issue only affects recent production perhaps? It’s obviously not widespread but I guess the question is if will it happen more as time goes on.
      05-09-2023, 03:52 PM   #46
caughtinflux
Drives: 2020 M2 Competition
It is the same part. Got this from my dealership. https://www.youtube.com/shorts/LERVpjUbk80
Love that the shifter design requires you put extra load into the system just to go in to reverse
chris7197334.00
      05-09-2023, 05:12 PM   #47
chris719
7334
Always at that weld. Pretty weird that it's only happening of late on M2s.
      01-17-2024, 03:36 PM   #48
silverds
337
Drives: you up a wall
Add another to the list of victims. This just happened to me today. 2020 M2C with just under 16K miles. Shift linkage broke just like others in the thread.
They are saying it's out of warranty so we'll see what they tell me.
      01-17-2024, 04:22 PM   #49
chris719
7334
Show them that previous video or this thread. They should step up because it's clearly a weld issue.
      01-19-2024, 03:58 PM   #50
silverds
337
Dealer just quoted $2199.20. Claims they need to drop the trans to repair.
Smells fishy.
      01-19-2024, 04:09 PM   #51
chris719
7334
Smells fishy.
I would fight, I would call BMWNA if you need to. This should be warranty no question.
      01-19-2024, 07:17 PM   #52
Mercules
Drives: 2017 OG M2
Smells fishy.
This⬆️
      01-19-2024, 11:35 PM   #53
maxcbrdriver
168
Drives: 2010 BMW 535xiT; 2021 BMW M2C
Smells fishy.
Definitely don't need to do that. It's the same work required to install SSK. Exhaust and front half of driveshaft get dropped, that's it.
      01-20-2024, 03:37 AM   #54
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Yeah but what you can get away with and what official BMW service instructions says are two different things.
Like BMW guidance to fix a crank hub slip is to take the engine out!
Go to an indy if bmw won't warranty it.
      01-20-2024, 08:45 AM   #55
maxcbrdriver
168
I followed the bmw repair instructions when I installed the SSK, they don't call for dropping the transmission.
chris7197334.00
      01-20-2024, 10:25 AM   #56
doughboy
doughboy's Avatar
1545
Ah ok that's good. I couldn't see why even bmw would say to do that.
Two hours labour my shop charges to fit ssk, £180.
And that is more work than just fitting a new linkage.
chris7197334.00
      03-31-2024, 04:34 PM   #57
sukutash
sukutash's Avatar
No_Country
66
Drives: 2011 335d, 2020 M2C
Originally Posted by grl.racr View Post
slow down on the curls! :P
m2
