M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Broken shift Rod
      02-22-2020, 02:00 PM   #1
ricko32
20
Drives: F87 M2C
Broken shift Rod
So this morning I park in my good no door ding spot at the gym and I go to put the car in reverse to straighten out and the shifter brakes off.
Not like in your hand but not connected to anything. You can spin it around.
Pulled off the boot and nothing obvious.
The car now at the dealership.
Pissed!
      02-22-2020, 03:15 PM   #2
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Pissed!
You have a manual? No need to take it to the dealer. Just pop it back in. I replaced my shifter it was a 2 minute job. No tools necessary.
      02-22-2020, 04:45 PM   #3
ricko32
20
Drives: F87 M2C
Yes manual. Cant pop back on. Shifter rod is broken. The dealer will have part Tuesday.
      02-22-2020, 05:45 PM   #4
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
That's crazy! I wonder how that happened. That thing looks strong.
      02-22-2020, 09:02 PM   #5
grl.racr
grl.racr's Avatar
383
Drives: G87 M2, MK8 R, RS6 Avant
slow down on the curls! :P
Appreciate 3
AndrewC198910931.00
TUDMG21.00
      02-22-2020, 09:44 PM   #6
detroitm2
detroitm2's Avatar
2429
Drives: 2018 M2
2018 BMW M2  [0.00]
Try switch hitting from time to time. Sounds like you buffed up miss Susie Right a bit too much.
2018 M2 - Daily Driver/Track Car
Motorcity BMWCCA Member
Instagram | YouTube
Appreciate 3
hlm2c289.50
AndrewC198910931.00
      02-23-2020, 09:40 AM   #7
pz619
3279
Drives: F87 M2C 6MT, Tesla 3
I’m actually shocked this happened. When I switched my shift knob I had to basically plant both feet on the ground, put the shifter in second gear and start doing dead lifts to remove the knob. Of course, when it finally did come off I punched myself in the face.
Are you sure it’s not just unseated? I only ask because the knob is just connected by friction, it doesn’t screw on like most cars. The linkage should simply have a notch in the center and the shifter just sits on top of it, held on by friction. You really have to slam the shifter down on the rod to get it to seat properly.
      02-24-2020, 02:16 PM   #8
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
I don't think OP is talking about the decorative knob coming off the shifter inside the car.
I think he means the linkage to the 'box under the floor plan has broken?
Can you clarify OP?
      02-24-2020, 02:16 PM   #9
ricko32
20
Drives: F87 M2C
it is not unseated. the shift arm is broken off,
Appreciate 4
pz6193278.50
nioh_lbbm21716.50
AndrewC198910931.00
      02-24-2020, 03:28 PM   #10
infinitekidM2C
infinitekidM2C's Avatar
4207
you must lift bro
      02-24-2020, 03:47 PM   #11
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
Now that's how you slam through the gears
      02-25-2020, 01:38 PM   #12
ricko32
20
Drives: F87 M2C
Name:  BROKEN SHIFTER.jpg
      02-25-2020, 03:41 PM   #13
pz619
3279
Wow. That's amazing. I don't think I've ever seen one sheared off like that. Recommend you consider a strong man competition.
      02-25-2020, 03:57 PM   #14
ricko32
20
Drives: F87 M2C
no strong man here just a crappy weld.
      02-25-2020, 04:00 PM   #15
infinitekidM2C
4207
Nah nah nah. We know a huge stud when we see one.
Appreciate 2
pz6193278.50
ROASTM163.50
      02-25-2020, 04:14 PM   #16
chief1richard
Life is on the Track, the rest is just waiting.
chief1richard's Avatar
381
Drives: At the point of 7,000 RPM's
2018 M2  [0.00]
New shifter
While your doing this you might consider putting in an Autosolutions Ultimate Short Shifter. I just installed one myself and the difference is incredibly precise shifts. That OEM Shift Arm is hollow rolled steel, tack welded where it broke off. Mine is sitting on my work bench, and I just inspected it. Autosolutions is much higher quality. Rifle Bolt like action.[IMG][/IMG][IMG][/IMG]
At a Point above 7,000 RPM.
      03-01-2020, 01:36 PM   #17
chief1richard
381
2018 M2  [0.00]
Oem shift arm
Cheap hollow rolled tube steel
      03-01-2020, 02:08 PM   #18
AndrewC1989
AndrewC1989's Avatar
10931
Drives: 2015 328d xDrive
Not sure how up to date this is but I stumbled upon UUC's comparisons of other SSKs and they seem to critique quite a few things about the Auto solutions kit. Curious what your thoughts are.
http://store.uucmotorwerks.com/artic...OMPARISONS.htm
      03-01-2020, 03:01 PM   #19
chief1richard
381
2018 M2  [0.00]
Just went to their site and read their reviews of other shift makers. The Autosolutions review is for a Kit rebuild. I bought an Ultimate shifter which is an entire new shifter already assembled. Cost was around $500. Some of the Cons I disagree with, like having to disassemble exhaust, and drive shaft. This is very easy to do, and not even required if you have small hands to access the clips. Also that the shifter is loose and worn out after 2 weeks. Mine is solid and tight, much better than the OEm one. I was very impressed with the quality and tolerances of the machined parts. I would search the forums for some of their shifters. I did and thats why I went with Autolutions.
      10-07-2021, 05:45 PM   #20
M2CintheSix
M2CintheSix's Avatar
29
Drives: BMW M2 Competition
Pissed!
Yep… same thing just happened to me ☹️
      10-07-2021, 08:15 PM   #21
chris719
7334
Drives: '08 M Roadster
What model year, out of curiosity?
      10-17-2021, 09:50 AM   #22
stefan
stefan's Avatar
No_Country
2354
Drives: M2 Comp
I would avoid UUC. I've used them twice. Love the DSSR in the E39 M5 and E46 M3. But in both the shifter retaining pins got loose over time. Great shifter at first but then nothing but headaches down the road for both of them. It's a dumb design and if they are still using that process with the blue loctite pins then I would pass on UUC.
///M Power
m2
