08-02-2013, 12:16 PM | #1 |
162
Rep 573
Drives: 2013 F30 335i 8SA M-Adaptive
I'm having my car aligned after I installed the H&R sport springs a few weeks ago (waited for them to settle)
I've settled on the following alignment targets 0.1 degrees toe out in the front 0.2 degrees toe in in the rear -2.0 degrees camber in the rear I'll post the results from the hunter when I'm get them. I'm doing an Autocross class this weekend then another Autocross the following Sunday. I'll let you guys know what I think of the settings. Anybody else F'd with their alignment yet? Anyone have a spec they like that they want to share?
08-02-2013, 02:23 PM | #2 |
162
Rep 573
Ok, done
Front camber (because of the H&R Sports) has increased neg camber from -0.4 to -0.6 degrees - gotta love lower Front toe set to 0.15 degrees of total toe out Rear camber read -1.5 degrees, we were able to get -2.0 degrees with no problem Rear toe is now 0.20 total toe in Car does feel a little more eager to turn - we'll see how it goes tomorrow (btw, front/rear initial readings Front 0.24 degrees initial toe in Rear 0.47 degree initial toe in ridiculous)
08-03-2013, 11:42 PM | #3 | |
122
Rep 586
G05 - M Performance roof spoiler
08-04-2013, 08:27 PM | #4 |
162
Rep 573
Autocross went really well - I could defiantly tell a difference in the slalom elements. Direction changes were much quicker and very balanced
On the freeway there's little change. It's no longer dying to go straight forward all the time, but there's not enough toe-out to make the car darty by any stretch of the imagination. Defiantly acceptable for daily driving. Steering input at lower speeds seemed to lightened up with the new alignment, about back to where it was before I put 245's on the front. As for tire wear, it was every bit as hot this weekend as it was last month - my front tires last month showed over 200 degrees internal temperature, this time they didn't get over 165. In fact when we'd been working the car quite a bit, both the front's and rears were within 5 degrees of each other (instead of the gross imbalance we saw last month) Forgiven, what spec are you running? |
08-05-2013, 12:36 AM | #5 |
122
Rep 586
Car is all stock except OE Camber bearing installed onto DHP M sport suspension.
Front Camber Driver side: -.93 deg Passenger : -.77 deg Front Toe : .1 deg on both side out(edit) Rear Camber Driver side: -2.1 Deg Passenger : -1.95 Deg Upcoming/ordered: Yoko ADVAN 245/40/18 will be slap on OZ Alleggerita HLT 18x8.5
08-07-2013, 09:48 AM | #6 | ||
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Are you running a square set-up with 245s all around? Quote:
Ahead of the curve for specF30
08-08-2013, 09:45 AM | #7 | |
162
Rep 573
http://www.f30post.com/forums/showthread.php?t=831520 |
08-08-2013, 09:49 AM | #8 | |
162
Rep 573
To avoid confusion, BMW calls that part a "Swivel bearing" |
08-08-2013, 10:32 AM | #9 |
558
Rep 1,477
Drives: 335i
Looks like the front camber numbers are stacking up pretty consistently:
Stock: -0.4 Lowered ~ 1": -0.6 Stock height/camber bearing: -0.9 So I guess with the camber bearing as well as an inch of drop, I could expect about -1.1 degrees of front camber. With regard to the rear camber, would you guys advise dialing in as much as possible during the alignment? I read somewhere that the ideal would be to have front camber numbers equal to (or even exceeding) rear camber numbers, but maybe that's only practical for a skilled track driver on a track-only car (?) To that end, with the camber settings at > -1, would you still advise a square wheel/tire set-up? Or would a slightly wider rear be appropriate with more front camber?
08-08-2013, 12:10 PM | #10 |
162
Rep 573
If we had camber plates, I'd be running about 1 degree of camber less in the rear than in the front
Assuming I could get there, I'd run -3.0 in the front -2.0 in the back and stick with the square setup Unless you're drag-racing it's front-end grip that we need to make the car balanced. Too much rear grip and the cars get pushy under power I agree with this guy's take for aligning e36 M3's http://forums.bimmerforums.com/forum...or-your-E36-M3 Weight bias on the F30 and suspension geometry isn't significantly different. The 335 is a little more nose heavy which puts even more importance on front-end grip. Until we get plates and test though, it's all a theoretical conversation. |
08-08-2013, 01:46 PM | #11 | |
558
Rep 1,477
Drives: 335i
So it seems like adding -0.5 degrees (or even 2-3x more than that) of camber is certainly not enough to warrant looking for more rear tire width. Is there any reason why you haven't gone with the OEM camber bearings yet? * Edit: Just posted an update on the Camber Plate availability thread
08-08-2013, 11:52 PM | #12 | |
122
Rep 586
08-09-2013, 09:14 PM | #13 | |
44
Rep 349
08-15-2013, 07:24 PM | #15 | |
162
Rep 573
This is my fastest, got a little ornery and overshot turn 2. Overall I thought the run was sloppy compared to my others-it was my last run so I was hanging it out. Even with all that crap, it was my fastest run. This car likes to be driven like a hoon apparently Need to work on my driver mod, I know I left at least a second out there |
08-20-2013, 12:26 PM | #17 |
162
Rep 573
Not true, all things being equal any toe (in or out) causes tire wear. The 10 minutes of toe out I'm talking about are less than the 14 minutes of toe in the factory suggests.
And all things are rarely equal - when a wheel has negative camber as ours do, a little toe out actually reduces wear as the toe counter-acts camber thrust, reducing rolling resistance. http://en.wikipedia.org/wiki/Toe_(automotive) |
