04-07-2020, 10:07 AM | #1 |
373
Rep 416
Pan Roof Noise
Anyone got a Pan Roof that makes a small creaking/clicking noise? Mine is right side of the car, me being 6ft 3" I'm picking it up a lot and it's beginning to drive me bananas!!
Tried WD40 and light bearing grease on the gaskets and any working parts I can think of, anyone having the same kind of issue? |
04-09-2020, 07:43 AM | #2 |
951
Rep 1,642
Have you got a wider shot of the Pano Roof? It looks nearly the same to our Mini one, which if it is the same cassette, creaks and knocks loads! I've found if you apply pressure up wards on the corner on the left or right side where it tilts up/down it stops the noise. Said noise resumes after letting go, tried adjusting ours to no avail, it's on my to do list to investigate further!
JustChris17423.00 |
04-09-2020, 08:06 AM | #3 | |
373
Rep 416
04-09-2020, 09:10 AM | #4 | ||
951
Rep 1,642
04-09-2020, 10:09 AM | #5 | |||
373
Rep 416
04-09-2020, 10:30 AM | #6 |
951
Rep 1,642
Yours is slightly different to ours, although pretty much the same concept - as it retracts externally rather than internally you find in the more expensive range of cars.
Ours only knocks and rattles when it's closed - so it only annoys us in winter as we usually have it open or on tilt most of the summer. The two things I will say on researching the issue with ours is the cassettes don't get screwed in well enough at factory - resulting in knocking and creaking. The other main culprit is the sun blind too - both these issues would cause a noise when it's still open. |
MrFoxy372.50 |
04-10-2020, 04:13 AM | #7 | |
373
Rep 416
