06-19-2021, 01:51 AM | #23 |
2354
Rep 2,041
Drives: INDIVIDUAL F90 M5C LCI
KW H.A.S. Kit
15MM Macht Schnell Spacers (front) 12MM Future Classic Spacers (rear) 285/35/20 (Front) Michelins 295/35/20 (Rear) Michelins Spacers and KW's from IND
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
11-01-2021, 03:43 PM | #25 |
Rep 16
I did this and have rubbing on back with 3 passengers in rear
11-01-2021, 10:00 PM | #26 | |
29
Rep 302
11-03-2021, 08:28 AM | #27 | ||
Rep 16
11-03-2021, 04:02 PM | #28 | |||
29
Rep 302
11-04-2021, 09:11 AM | #29 | ||||
Rep 16
11-16-2021, 08:58 PM | #30 |
258
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
This is interesting and thanks for letting us know about the rubbing. I’m not lowered (yet) and was going to do 15F/12R until you mentioned rubbing in the rear.
Do you think going 2-3mm thinner in rear would prevent any rubbing? |
11-16-2021, 09:19 PM | #31 |
29
Rep 302
Same thing. I don't want a to run. Maybe 10mm rear
11-24-2021, 09:14 PM | #32 | |
276
Rep 655
Removing them might get you some more clearance. |
03-07-2024, 12:00 PM | #34 | |
Rep 13
03-11-2024, 12:41 PM | #35 |
1719
Rep 1,913
Drives: 2023 M5C
You won't rub with a lowered 15/12 setup. I'm lowered with 17/11 Dinan spacers and no rubbing issues.
IG @windtendo_m5
04-09-2024, 01:53 PM | #36 |
Rep 13
04-30-2024, 12:57 PM | #37 | |
246
Rep 562
Drives: 2018 M5 / 2011 X5 35d
I have the exact same setup (not lowered) 15mm front / 12mm rear with 295s on the back and 285 on the front but tires stick out a tiny bit, not fully flushed with the fenders. Wonder why? |
04-30-2024, 09:32 PM | #38 |
4082
Rep 5,236
Since he’s lowered, it is probable he had an alignment performed and tucked the wheels slightly w/ negative camber.
The owner’s a friend and he’ll more than likely respond to confirm. I’m on 21” wheels, KW V4’s and 295-285 Michelin PS4S and had an alignment performed after the coilovers settled .. I was able to tuck slightly inside the fender for a more flush look.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
FSHNGRY2353.50 |
05-01-2024, 06:58 PM | #39 | |
246
Rep 562
05-04-2024, 08:23 PM | #40 | |
2354
Rep 2,041
05-08-2024, 01:38 PM | #41 |
1719
Rep 1,913
Drives: 2023 M5C
IG @windtendo_m5
