04-11-2024, 09:17 AM | #1 |
62
Rep 146
Vanos Covers
How good are the vanos covers from Evolve? Im doing NRW valve covers and plugs and everything related very soon. I might as well do the vanos covers as well. What are y'alls thoughts?
04-11-2024, 11:41 PM | #2 | |
94
Rep 83
I知 also doing the throttle actuators (better rebuild ones) at the same time, as well as the vanos covers. However I opted for the Mporium bolt on vanos covers, I知 not saying the Evolve ones are not good, but the bolt on ones from Mporium look to be a better solution in my personal opinion. The Mporium ones are a bit more labour intensive to fit though, as they require the motor to be re-timed, as they involve removal and replacement of the vanos stretch bolts (if you get the complete kit from Mporium it includes OEM stretch bolts and also the gaskets for the vanos cover housing). |
04-12-2024, 09:16 AM | #3 | |
62
Rep 146
Johnny E9293.50 |
04-24-2024, 01:30 AM | #4 |
Rep 7
I have a friend whose Vanos unit spring exploded and put a hole in the valve cover and upper timing cover. After seeing this I don't think the clip-on covers can handle that force. Something to think about.
04-24-2024, 02:00 AM | #5 |
1594
Rep 1,114
Drives: 2009 E92 M3 Dakar Yellow II
Your friend had bigger problems than his choice of vanos caps if his spring exploded. The plastic caps would never have prevented that either. Nothing short of Carbahn or Mporium caps would have worked but again, what causes the spring to dislodge in the first place?
amg6975500.00 |
04-25-2024, 02:03 PM | #6 |
50
Rep 511
I知 going to get my vanos covers changed and NRW valve covers fitted.
Can this be done without changing the oil - or does the oil need to be drained? I知 asking because my oil is only a couple of thousand miles old, so if it doesn稚 need to be drained I壇 rather leave it. |
04-26-2024, 07:42 PM | #8 | |
94
Rep 83
05-04-2024, 10:09 PM | #9 |
204
Rep 175
I have the Evolve caps. They're developed by Mr. Vanos so I don't expect them to have issues, but only time will tell. The MPorium/NRW caps are a superior alternative, but the installation is much more involved than the snap on covers. Something to keep in mind if you're planning to DIY.
Today, 06:29 AM | #10 | |||
594
Rep 1,036
Drives: BMW M3 e92 08 & 330d e90 10
Agreed they're stronger, but overkill IMO. Quote:
Assuming something else didn't happen, what probably happened to your friend's car is that the plastic cover dis-integrated and the spring gradually walked off. These covers do restrain the spring, but clearly their isn't much force involved or the plastic covers would've failed a long time ago. Clip on ally covers are plenty strong enough to keep the springs in place.
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
