07-27-2012, 12:39 AM | #1 |
Supreme Allied Commander
3888
Rep 54,538
Drives: F80 M3
Ohlins R&T for BMW 1M
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! 2-year limited warranty on all of our products - worldwide. General Features *DFV (Dual Flow Valve) *Rebuildable *Corrosion salt spray tested (ISO 9227) *2 year Limited Warranty Front McPherson Strut *Single bleed adjuster *Spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 60N/mm) *Height adjustable bottom mount to prevent preloading or unloading of the spring *Dustcovers *Use with original top mounts or camber plates Rear Conventional Shock Absorber *Single bleed adjuster *Separate spring preload adjuster (approx. 20 mm lower than standard) *Coil Springs (rate 110N/mm) *Dustcovers *Use with original top mounts ***Custom Swift Springs are also available with special spring adaptors*** ***Compatible with NEW Vorshlag M3 camber plates*** ***Kit due to ship in at the start of 2013*** Have a read at the positive reviews from 135i and 335i owners on the Ohlins R&T product: http://www.e90post.com/forums/showth...ghlight=Ohlins http://www.1addicts.com/forums/showt...ghlight=Ohlins http://www.1addicts.com/forums/showt...ghlight=Ohlins [u2b]http://www.youtube.com/watch?feature=player_detailpage&v=qkx5DD8QEwg[/u2b] Last edited by HP Autosport; 12-29-2015 at 03:36 PM.. |
08-22-2012, 11:17 AM | #2 |
3888
Rep 54,538
Drives: F80 M3
Ohlins R&T BMW 1M
Looks like the realease has been pushed to October now.
10-09-2012, 05:41 AM | #4 |
11
Rep 161
Soon available for E46 M3 too.
Ohlin is using a club member's car.
10-09-2012, 12:18 PM | #5 |
3888
Rep 54,538
Drives: F80 M3
10-09-2012, 03:52 PM | #6 |
192
Rep 4,848
Good news!
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
10-09-2012, 05:33 PM | #7 |
119
Rep 898
Drives: '69 GT3, GT4, 1M, 912
By the way, there are two solutions from Ohlins currently available for the 1M. Both are rather track focused. One is the solution mentioned in this thread developed by Ohlins USA, released a bit over a month ago:
http://www.1addicts.com/forums/showthread.php?t=625284 The other is likely an even higher end solution targeted at competition cars, available from Performance Shock Inc. Both are probably more expensive than the upcoming R&T solution, but both are also likely higher performance for track work and competition applications.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
10-12-2012, 05:22 PM | #8 | |
3888
Rep 54,538
Drives: F80 M3
For street duty and track days, Road & Track will be perfect and nearly half of the price. |
11-02-2012, 01:15 AM | #9 |
3888
Rep 54,538
Drives: F80 M3
Updated photos of the Ohlins E82 1M kit.
More technical info here: http://www.m3post.com/forums/showthread.php?t=765106 |
11-12-2012, 09:33 PM | #11 |
3888
Rep 54,538
Drives: F80 M3
12-13-2012, 07:46 PM | #12 |
3888
Rep 54,538
Drives: F80 M3
Ohlins R&T BMW 1M
Pricing and release date from Ohlins USA. For more info:
http://www.m3post.com/forums/showthr...5#post13153465 |
12-26-2012, 11:21 AM | #14 |
3888
Rep 54,538
Drives: F80 M3
01-04-2013, 09:08 PM | #16 |
3888
Rep 54,538
Drives: F80 M3
01-16-2013, 06:20 AM | #19 |
3888
Rep 54,538
Drives: F80 M3
01-16-2013, 08:34 AM | #20 |
45
Rep 108
Are they shipping yet, Harold?
1996 Trans Am WS6 (RiP)
2002 Trans Am Collector Edition WS6 - Not Stock @ 425 rwhp 2006 VW GTi - APR Goodies - Sold 2011 1M - VO Florida pick up 11/4/11 #554 of 740 - Sold 2017 ATS-V Stock |
01-17-2013, 06:52 PM | #21 |
3888
Rep 54,538
Drives: F80 M3
Here are some photos with the Swift spring upgrade.
Rear is easily done and we used the quick change rear spring kit so the main spring can be changed easily. Front is a bit more involved when NOT using camber plates. An adaptor had to be custom made for the OE strut top mount to accept a constant ID coilover type springs, but as you can see the result is awesome and look very OE like. A shorter spring can be used to allow the highest lower spring perch position for wider wheel/tire clearance. Last edited by HP Autosport; 02-26-2013 at 07:45 PM.. |
02-03-2013, 11:11 AM | #22 |
593
Rep 5,396
What is the minimum drop on the 1m?
It would be nice to be able to have a nice road / track handling upgrade without having to drop the car since I like the stock ride height. Should also ride best at the max height. Thanks, and can you go into more detail on the installation issues on the front? Does this apply with the out of the box kit with Ohlins supplied sprigs? Thank you!
