04-10-2017, 04:51 AM | #111 |
45
Rep 46
Hi,
Does any of you have the TUV documents for the 1m kit BMZ MN01? I have this kit on my car that I recently purchased but the TUV documents was missing. Need this document for the Norwegian "DMV". If some of you have this, a colored copy would have been very helpfull. Thanks.
BMW 1M 2011. Akrapovic Evo exhaust w/wireless kit, AR design DP, , Wagner EVO I IC, Cobb chargepipe, Turbosmart Diverter valves, AFE GT Momentum intake, MMP inlets, Cobb Accesport with custom Buraq map, BMS oilcatch can, Setrab 2nd oil cooler, Rogue short shifter, Ohlins R&T suspension, Brembo 18z brakecaliper w/Ferrodo DS2500 pads, Recaro CS seats
04-15-2017, 12:13 PM | #112 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
I just checked, no TUV documents with my US-spec kit, sorry. Have you contacted Ohlins directly? I'll bet they could email you a PDF of what you need.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
04-18-2017, 02:18 PM | #113 | |
45
Rep 46
Ohlins can provide this but I need to "apply" and pay for them to send it to me. So therfore wondering if some of you had this document. It is the same document for all 1M kits.
05-04-2017, 10:04 AM | #114 |
196
Rep 657
Hey guys, can anyone tell me what camber is approximately on the front with the recommended 17mm ride height drop? How much +/- adjustment is there? I'd like to achieve -2 to -2.5 level, can this be done without camber plates?
05-04-2017, 10:41 AM | #115 |
45
Rep 46
Hi, just had alighment done. Mine is lowered around recommended from Ohlins and they managed to get -1.5 camber without pulling the pins. Not sure how much extra you get when pulling the pins, but i belive you need camber plates to reach more than -2.0 camber
05-06-2017, 09:40 PM | #116 |
Supreme Allied Commander
3888
Rep 54,538
Drives: F80 M3
When I had my 1M I was able to get -2 just by lowering the front about 1" over stock.
05-08-2017, 02:49 AM | #117 |
45
Rep 46
Really, did you pull the alighment pin to get -2?
05-08-2017, 04:17 AM | #118 | |
196
Rep 657
That's a lot of drop though! Front clearance especially with a lip would be minimal. |
05-09-2017, 01:22 PM | #119 |
3888
Rep 54,538
Drives: F80 M3
05-07-2024, 03:50 PM | #120 | |
Rep 2
Does anyone have Harold's contact info? I have a 2010 135i and a chance to buy a full set up R and T for the years 11-13 1M. If I'm reading this thread it will not work. However, I've read other threads stating the set up will work? Now I'm confused. Any insight is greatly appreciated. Last edited by Tews; 05-07-2024 at 03:55 PM.. Reason: Grammar |
05-07-2024, 03:53 PM | #121 | |
3888
Rep 54,538
Drives: F80 M3
