07-31-2019, 11:34 AM | #111 | |
828
Rep 2,232
Your best bet might be the local BMW dealer? Unless you can find one for sale locally (check the regional section of the forums). Part # is 18-10-2-208-806 |
08-01-2019, 02:03 PM | #112 | |
13
Rep 45
10-06-2019, 03:16 PM | #113 |
Save the manuals!
6028
Rep 6,753
Welded shut the pipe with the 3 large holes and the pipe with the perforated smaller holes. The car sounds amazing! So good under load with a nice mellow tone all around.
N55, stock downpipes, stock resonator. PPK tune. There is more bass down in the 1-3K RPM but nothing I would consider droning. Best bang for the buck mod on this car. I'm considering adding the PE y-pipe to delete the resonator. Anyone else running that with the PE modded muffler but stock downpipes on a N55?
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
12-16-2019, 02:34 PM | #114 |
767
Rep 904
For those referencing this thread, I wanted to mention that the N54 muffler not only has the holes in these two pipes in the center section, but it also has perforations in both pipes in the first y-section of the muffler, so this mod won't likely work as well. So, the N54 and N55 mufflers are different, and most of this thread is in reference to the N55 muffler. You'd have to cut open two chambers of the N54 muffler to get the same effect.
04-07-2020, 01:54 PM | #116 |
137
Rep 952
Thanks for posting this. I recently put an E82 N55 muffler on my E84 N55 and it sounds completely different. I could see the perforated section right on the inlet to the muffler, but damn that's completely different. Interesting that they're almost identical on the outside.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
Duchess2244.00 |
12-10-2020, 08:10 PM | #118 | |
44
Rep 157
Thanks!!!
Pay attention to the person behind the one in front of you.
06-05-2023, 11:23 PM | #119 |
18
Rep 22
Bumping an old thread but I'm new to my 135i and am looking for exhaust choices. This sounds like an interesting option to try.
But I need to confirm, doesn't closing the holes (big and small) on both pipes inside the muffler essentially deletes the muffler? This "OEM PE" mod is basically a straight pipe setup right? Am I missing something here? |
06-05-2023, 11:42 PM | #120 | |
16
Rep 87
Some people are closing both pipes. |
06-06-2023, 09:06 AM | #121 | |
18
Rep 22
And the real PE exhaust should have roughly the same sound volume as the muffler "bypass" in this thread: https://www.1addicts.com/forums/show....php?t=1221654 or this: https://bestmufflers.com/bshop/Custo...dification.htm Correct? |
06-06-2023, 09:10 AM | #122 | |
16
Rep 87
I suggest catless + pe it's by far the best sounding setup. |
06-22-2023, 08:18 PM | #123 |
18
Rep 22
Had this PE mod done today. I only had the three big holes closed up and left the small perforated pipe alone. Everything else stock: stock downpipe, stock mid pipe resonator, and the exhaust valve still plugged in.
Turns out this is a very tame volume increase. Just enough to finally hear the exhaust but not at all obnoxious. I was worried that it might be too loud but it's very very civilized. I may even delete the resonator in the future. Leaving the valve in place, the car is basically stock during gentle driving. But give it some hard throttle and the valve opens up and the exhaust sings. I can even hear a little bit of burbles and pops now. I may try the "golf-tee" mod in the future to keep the exhaust valve open all the time. Anyway, thanks to the OP and all that contributed to this thread. It's a great alternative to aftermarket axelbacks and catless downpipes. |
Fishee1043.00 |
06-22-2023, 08:18 PM | #124 |
16
Rep 87
You need the resonator delete to do a proper pe, also the proper pe has a valve delete so do the golf tee
06-22-2023, 09:33 PM | #125 |
18
Rep 22
I know. I was worried it might be too obnoxiously loud so I decided to make changes incrementally. Might try golf-tee mod next, then maybe eventually resonator delete. So far, I'm satisfied with the extra volume. And I like that I can fly under the radar and act stock if I drive gently and keep the valve closed.
06-22-2023, 10:38 PM | #126 |
16
Rep 87
Golf tee is easy to do, can just unplug a cable in the trunk (peel back the lefthand carpet and unplug it). Youtube tutorial somehwere.
You should do catless since you also live in canada, I just drilled mine out lol and it sounds amazing and is still suprisingly quiet. |
08-28-2023, 08:36 PM | #127 |
Rep 1
Anything in life worth doing is worth overdoing.
https://www.newbloggingaboutanything.com |
