08-15-2022, 07:53 AM | #1 |
66
Rep 86
Rear subframe brace - 340xi
Installed rear subframe brace. What a difference it makes! The rear end is much tighter! Took it out on back roads after, much improved!
I do plan on replacing the subframe bushings this winter. Next will be the front subframe brace and control arms. |
08-17-2022, 03:38 PM | #2 |
6461
Rep 8,524
I can thoroughly recommend Whiteline rear subframe bushes - I had them installed a couple of thousand miles ago and they've made a big difference to the control of the rear of the car on my F31 which has a rear subframe brace as OEM spec.
There's a little bit more NVH but I'd put in the "negligible" category.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
sdbwisc66.00 |
08-17-2022, 03:42 PM | #3 | |
66
Rep 86
Weird how the F31 came with brace but not the F30. |
08-17-2022, 05:27 PM | #5 |
66
Rep 86
02-22-2023, 02:39 PM | #6 |
118
Rep 328
Direct bolt on to 340i?
02-22-2023, 04:18 PM | #7 |
2523
Rep 1,844
it is, I have one waiting to be installed on my 340, looks like they're out of stock of the brace right now.
there's also an OEM alternative, you can read it in this thread: https://f30.bimmerpost.com/forums/sh...1080995&page=4
02-22-2023, 04:32 PM | #8 | |
118
Rep 328
02-22-2023, 04:36 PM | #9 |
2523
Rep 1,844
basically the middle braces is thickened versus oem (F80 OEM middle brace is thicker than F30), then the two connecting arms that connect middle brace to rear sub frame, that same type of bracing exists on F33 convertibles. Rolls basically made a thick forged aluminum version of what people have been piecing together using OEM parts from F80/F33's. That's also the upside of the Rolls performance one, its not pressed steel like the OEM pieces are.
02-22-2023, 04:39 PM | #10 | |
118
Rep 328
02-22-2023, 04:48 PM | #11 | |
2523
Rep 1,844
02-22-2023, 04:55 PM | #12 |
118
Rep 328
02-23-2023, 03:53 PM | #14 |
66
Rep 86
I didn't do anything this winter, didn't get my shop insulated yet, I hate the cold lol.
Lower control arms are a must. Huge for handling. I just bought more parts, I'll be buying more soon. Need to get installing these soon! |
Ivilla035118.00 |
02-26-2023, 09:34 PM | #15 |
118
Rep 328
For sure. emailed ross racing, still debating whether i pick up the mid chassis brace. He said it's an easy install.
11-14-2023, 11:48 AM | #16 |
147
Rep 236
Drives: 340i xDrive Stage 1
Hi I bought these and plan on installing them myself, do you know the torque spec for these by any chance?
11-14-2023, 12:07 PM | #17 | |
2523
Rep 1,844
isenc2146.50 |
11-14-2023, 01:11 PM | #18 |
2477
Rep 5,460
Drives: F30
Running the F80 tunnel brace on my F30. Just wanted to comment that it is definitely not pressed steel like indicated above. Its thick aluminum and a cheap pickup from the local junk yard. Definitely stiffer than the F30 brace, which is indeed stamped steel.
Incorrect/ misleading statement: "Rolls basically made a thick forged aluminum version of what people have been piecing together using OEM parts from F80/F33's. That's also the upside of the Rolls performance one, its not pressed steel like the OEM pieces are." |
11-14-2023, 01:18 PM | #19 | |
147
Rep 236
11-14-2023, 02:43 PM | #20 | |
2523
Rep 1,844
12-14-2023, 08:10 PM | #21 | |
148
Rep 552
How did your mechanic know the torque settings since the brace isn't oe. For that model? I'm doing something similar and am concerned the shop will not torque enough or too much. Given its keeping the subframe together, it's quite crucial to get right. |
12-18-2023, 12:18 PM | #22 | |
66
Rep 86
