03-08-2019, 08:18 PM | #1 |
228
Rep 212
Drives: 2024 M3 Comp xDrive
F87 vs F80/F82 Comfort/Daily Driveability
Hey all,
Not sure if there has been a discussion on this in the threads thus far, but I was wondering what the general consensus was on the comfort of the M2 vs the M3/4 in terms of daily drivability. I just recently picked up my F87 (3 months ago) as a daily driver and find that it is a bit stiff suspension wise. Is this problem resolved with the adaptive suspension of the F80/F82 or is the difference somewhat negligible? Any and all opinions appreciated. Cheers! |
03-08-2019, 08:22 PM | #2 |
1086
Rep 1,405
Having had the 2016 F80 M3 - honestly I can't say it was any more comfortable than my current 18 F87 M2. Unless they did something with the M3's suspension in the more recent years, I would say that they are both equally 'not as comfortable' on crappy roads.
m2for2228.00 |
03-08-2019, 08:24 PM | #3 | |
228
Rep 212
Also, was yours comp pack or not? |
03-08-2019, 08:33 PM | #4 |
1086
Rep 1,405
That's my understanding as well in regards to the adaptive suspension although I am not sure. I did not have competition pack. On a day to day basis it was at least as much (if not more) uncomfortable/stiff than the M2. The added weight and bigger dimensions of the vehicle makes the rolls (when trying to avoid potholes) and pothole wobbles were more noticeable if anything.
03-09-2019, 12:17 PM | #5 |
262
Rep 561
Drives: '23 M5 Comp
The adaptive suspension in the F80/82 in comfort mode was a lot more compliant than the M2 suspension. I had a '15 M4 and a '17 M2. I found the M2 suspension almost too harsh for a DD and I like a sport tuned suspension in my cars. I only used the comfort mode setting in the M4 when I was on long trips of several hours.
doug_9992544.50 biggripper728.00 |
03-09-2019, 01:59 PM | #6 | |
228
Rep 212
03-09-2019, 03:07 PM | #7 |
197
Rep 430
Drives: 2017 M2 LBB 6MT; 2012 328i 6MT
Did yours come with Michelin or Continental tires?
If you haven't replaced the initial set (I only got 10,000 miles on the Contis and replaced them with Michelin Pilot Sport 4S), your next set of tires may help a little depending on what characteristics you're looking for. https://www.tirerack.com/tires/surve...e&cameFrom=TSR |
03-09-2019, 04:28 PM | #8 | |
228
Rep 212
03-09-2019, 07:20 PM | #9 |
380
Rep 462
as mentioned this also has a lot to do w/ your wheel/tire setup
I'm planning on going w/ a new 18" wheel when it comes time to replace tires
"... if he fails, at least he fails while daring greatly, so that his place shall never be with those cold and timid souls who knew neither victory nor defeat.” —Theodore Roosevelt
Instagram@particulardude |
03-09-2019, 07:57 PM | #10 |
228
Rep 212
I feel as if a greater impact would be made by the size of the rim for sure. The 19" rims are a probably a big contributor to the harshness of the ride.
03-09-2019, 09:11 PM | #11 | |
Luxury at the redline :)
9108
Rep 7,563
Going down from 19 inch summer wheels to winter 18s makes a discernible different in how my vehicle absorbs NYC crater-size potholes.. Almost a night and day difference. However, still believe adaptive suspension would help in this regard also, since it gives you option to soften the dampening rate. |
03-10-2019, 02:15 PM | #12 | |
228
Rep 212
03-10-2019, 03:02 PM | #13 |
1125
Rep 2,564
Interesting since I've heard people say the M2 is really not any worse than the F80. My F80 with adaptive isn't great in the city either so I need to dodge potholes, etc but since 95% of my driving is on country roads, it's great. Need to test drive one.
03-10-2019, 03:39 PM | #14 |
684
Rep 1,608
I owned an '11 135i prior to my M2 and quite honestly, that ride was quite a bit harsher, due in no small part to the early runflats the car was equipped with. Considering the performance level the M2 achieves, I find the ride quite acceptable for most road conditions. Its not a Camry, but what the hey....
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 |
03-10-2019, 08:07 PM | #15 |
11
Rep 27
I find that the one downfall to this otherwise amazing car ('18 LCI) is the poor ride quality.
Granted I daily drive all year round in war-zone like roads here Massachusetts, but for me it's just too harsh, even with my 18" winters. I'm seriously considering a second car as a comfortable daily driver to break things up. Or a CPO 991... |
03-10-2019, 08:50 PM | #16 | |
Moderator
30017
Rep 13,167
Complicated to generalize if we're dealing with a set of different parameters.
///M is art ↔ Artemis
03-11-2019, 07:26 AM | #17 | |
1125
Rep 2,564
03-11-2019, 08:15 AM | #18 |
1996
Rep 1,759
I actually found the suspension on the F87 a bit soft as a sporty car...softer than the 1M and I used to daily the 1M with no drivability issues. Think I might need to get the M performance suspension now...
03-11-2019, 12:28 PM | #19 |
2052
Rep 3,714
Very similar in suspension feel, my F80 has adaptive suspension and it might be a tad softer in comfort mode vs. M2 suspension but not much difference. Your choice in tire can have a larger effect than the difference in suspension.
M3 will have a bit more interior and trunk room, that's about it. |
03-11-2019, 03:31 PM | #20 | |
228
Rep 212
03-11-2019, 04:45 PM | #21 | ||
9108
Rep 7,563
If I wasn't such a BMW fanboy, that vehicle would be on my short list.. |
03-11-2019, 05:40 PM | #22 | |||
1125
Rep 2,564
