2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB What's the best tranny oil to use for our m235i?
      06-11-2015, 08:07 PM   #1
PASE624
52
Drives: 2012 X1
Hey all,
I have a 2015 M235i without LSD. What is the best/recommended (by forum ppl, not "stealership" ppl) tranny oil to use in our m235i? Also, How many do i need to buy?
2021 X5 40i, 2021 M850i, rest is history
      06-12-2015, 07:43 AM   #2
EEBreh
123
Drives: "M" 235i
Mike Miller recommends Redline MTL. With that being said, you should use the factory fill. If anything happens to your transmission under warranty and BMW does an oil analysis, they will see that the oil was not "factory fill" and will probably deny a warranty claim. It's definitely a good idea to change it, but I would definitely use the factory fill while the car is still under warranty.
I believe you need a little under 3 liters. This link should help you...http://www.1addicts.com/forums/showthread.php?t=620282 . Check Realoem to make sure its the right part number.
Originally Posted by pkwon9285 View Post
Hey all,
      08-03-2015, 08:18 PM   #3
PASE624
52
Drives: 2012 X1
mine is Auto transmission, though.
      08-03-2015, 10:06 PM   #4
overcoil
3074
Drives: M235i 6spd
For an auto-trans I would ONLY use BMW specified fluid.
      08-04-2015, 01:07 AM   #5
PASE624
52
Drives: 2012 X1
might you guys happen to know what the part number is for the auto 8spd transmission oil?
      08-05-2015, 07:03 AM   #6
Zooks527
310
Drives: 2015 M235xi / 2005 Tacoma 4x4
83222305397 or 83222289720
http://www.realoem.com/bmw/enUS/show...diagId=24_1233
It is not inexpensive (ok, at $25 to $50/qt, I think it's stunningly overpriced), and, as noted above, either it or ZF Lifeguard 8 are the only things you should use.
From memory on my 335, the ZF transmissions take somewhere around 6 quarts, including the amount held up in the torque converter.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/BimmerTech amp, Enhanced BT
Prior 40 years: 67 BelAir wagon / 68 LeMans Tempest / 70 Mustang Mach 1 / 72 El Dorado / 78 Corvette / 81 Subaru GL wagon 4WD / 83 s10 Blazer 4x4 / 85 Bronco 4x4 / 96 Bronco 4x4 / 04 Passat 4mo / 09 BMW 335xi
      08-06-2015, 08:53 PM   #7
PASE624
52
Drives: 2012 X1
mine is RWD, not AWD. does it make a difference?
      08-07-2015, 08:42 AM   #8
Zooks527
310
Not if it's an automatic. The AWD and RWD versions use different versions of the transmission, but they take the same fluids.
http://www.realoem.com/bmw/enUS/show...diagId=24_1132
2addicts
