      08-31-2020, 01:42 PM   #1
dominguez255
Drives: BMW Serie 1 F40
Change color ambient
Hello,
I can changed the color ambient in my 118i F40, now the color bronze is red.
BDC module > Expert coding > 360A LicLciColorLibrary > LIC_LCI_COLOR_LIBRARY_DATA >UNK_PARAM_18 (selected option) > Custom value
Byte 13 14 15 : D7 6E 14 to FF 00 00
Byte 18 19 20: D7 6E 14 to FF 00 00
Original RGB hex codes are:
90,E0,90 - WHITE
D7,6E,14 - BRONZE
93,1A,01 - ORANGE
00,20FE - BLUE
10,FE,32 - GREEN
78,3C,FE - LILAC
you must change the bits of the color you want to change, they are two series of 3 bytes, as in the previous example.
MrFoxy376.50
      08-31-2020, 03:19 PM   #2
Gregus330i
Gregus330i's Avatar
102
Drives: BMW 330i M Sport
Thanks for sharing this!
      09-01-2020, 07:42 AM   #3
knali8
knali8's Avatar
438
Drives: 2021 X3M Comp
Nice
      09-01-2020, 12:25 PM   #4
dominguez255
: threadjacked:
Originally Posted by knali8 View Post
Nice
You will be perfect with that car !!
      09-01-2020, 01:21 PM   #5
Gregus330i
Gregus330i's Avatar
102
Just done this, so I have red now (wording is still bronze).
There must be a way of having footwell lights on while driving like in a Golf R - which were blue, I added blue bulb, and variable brightness also.
I saw carpet light in expert mode but there's too many settings to experiment!
MrFoxy376.50
      09-01-2020, 01:49 PM   #6
dominguez255
Yes, the name of the color and the color as such in the idrive display, I don't know if it can be changed, I'll investigate.
Regarding the light of the mat, it's interesting, I'm going to fiddle a bit to see what I find
MrFoxy376.50
      09-01-2020, 01:52 PM   #7
dominguez255
It was difficult for you to change the bulb, where can I find a replacement?
      09-01-2020, 04:30 PM   #8
Gregus330i
Gregus330i's Avatar
102
No, the blue bulb I changed was in a previous VW Golf R, a car where the footwell lights were always on, with variable brightness adjustment.
I feel there's a way to code our BMW footwell lights on all the time, but the options in expert mode are very many so we need to really know which settings to actually code. The footwell lights are white but I'm sure we could find some different colours, like blue or red, maybe on Ali Express. That's where I bought my M logo door lights, which are exactly the same light size & fitting as the footwell and boot lights
      09-09-2020, 12:25 PM   #9
rich345
Drives: BMW M135i
Hey.
i have just given this a go and changed bronze to red,
when it did it it did the restarting ecu, but it did not restart, like i have seen with others. it then popped up with side light failure.
Did yours do this?
      09-09-2020, 03:20 PM   #10
dominguez255
Originally Posted by rich345 View Post
Hey.
Did yours do this?
Not, What parameters did you change?
      09-09-2020, 03:31 PM   #11
rich345
Drives: BMW M135i
Hiya i did this
and these bytes
13 14 15 / 18 19 20
43 44 45 / 48 49 50
I have now had the car on in the dark and the DRL's work and all the other lights to. it also does not say anything when the car is started.
So everything seems ok, just thought it was a bit odd.
What is strange there is more than just "UNK_PARAM_18" there are a few and they are all matching the 18..
      09-09-2020, 09:54 PM   #12
LaVitaEBella
72
Drives: 2016 BMW M3
Thank you for sharing these information, will probably use it in the future.
      09-10-2020, 02:05 AM   #13
Lambster
Car go brum
Lambster's Avatar
Drives: BMW M135i (F40)
Hey.
Did yours do this?
I get that from time to time, I'd hazard a guess that the module is just restarted and the sensor just throws a wobbly. Goes away with a restart.
      09-10-2020, 04:05 AM   #14
rich345
Drives: BMW M135i
Yea that's what happened, just made me a bit like crap ive broke my car!
