New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      05-05-2024, 09:06 AM   #1
cinellipro
cinellipro's Avatar
Drives: BMW Z4
Is there an Optimal Oil Level for 3.0 N52 Engine
Greetings. I have a manual 2009 3.0. Changed the oil this morning and spent way too much time chasing the level indicator to reach MAX. I always let the oil drain until there are no drops. My car is a daily driver with 25k miles, and I change my oil every 6 months.
I'm not an engineer or physicist, but when changing our oil is there an Optimal oil level for the N52 Engine? Should I always aim for MAX or is the half-way point sufficient for proper oil circulation, temperature, pressure, etc? This is not about dollars, its about not having a dipstick.
Would love to hear from our experts.
Cheers!
      05-05-2024, 09:08 AM   #2
cinellipro
cinellipro's Avatar
Drives: BMW Z4
Tools oil and additives
      05-05-2024, 11:45 AM   #3
B21
B21's Avatar
167
Drives: E89 Atacama Yellow 35is
You should top it up to max..but…be aware that it may take a long time for the oil reading to fully stabilise..like 20-50 miles..so I’d put the recommended amount in..then run it for a period as prescribed before putting SMALL amounts of extra oil in..
On my cars I get it topped up then monitor it..when the oil level after due time shows about 1/2 full I put a measured 1/2 litre in..
From minimum to max is 1 litre..but it’s much easier to overfill than under fill..
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0
Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886
      05-05-2024, 01:04 PM   #4
cinellipro
cinellipro's Avatar
Drives: BMW Z4
B21- great suggestion. I'll run it a bit to let the oil settle in, then measure again.
Still wondering about the optimal volume though.
Cheers
      05-05-2024, 03:33 PM   #5
B21
B21's Avatar
167
Here you go
zpost
