New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      04-25-2023, 04:12 PM   #1
etropic
Drives: BMW E89
DSC value coding possible?
Is it possible to change the values where DSC engages ?
For the M3 this is something like the "euro MDM" coding.
Can we do something equivalent to this?
Goal is to reduce engagement for track use without having to turn DSC off completely.
edit: Looks like you can at least turn off a lot of the engagement via NCS Expert. I"m going to play with that. Open to ideas or info...
      04-27-2023, 03:12 AM   #2
B21
B21's Avatar
167
Drives: E89 Atacama Yellow 35is
Yes you can , guys on spool street have been doing this..suggest you wander across there..
That’s a separate issue from turning various ‘nanny’s’ off
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0
Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886
      04-27-2023, 01:50 PM   #3
etropic
Drives: BMW E89
thanks for the rec. already finding some info!
      04-28-2023, 05:06 AM   #4
B21
B21's Avatar
167
Let us know your thoughts
      05-02-2023, 01:30 PM   #5
etropic
Drives: BMW E89
Tons of good info there thanks!
I got a few values around "nannies" but there are several others that are mentioned frequently that are not in the module for my Z. The threads meander a bit so i'm still researching.
zpost
