Will hardwiring a GPS void my warranty?
03-09-2010, 06:36 PM | #1 |
Rep 37
I searched for this, but couldn't find anything specifically pertaining to a GPS. About a month ago, my boyfriend hardwired my GPS under the center console and into the center compartment. It's nice to have less wires showing, but I don't want to keep it hardwired if it somehow affects the warranty.
03-09-2010, 06:39 PM | #2 |
363
Rep 5,873
Drives: m
Yes for sure. Anything even unrelated stuff can void a warranty. No joke.
03-09-2010, 06:44 PM | #3 |
167
Rep 7,433
+1 take it firsthand from him. He's going through that hell right now.
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
03-09-2010, 06:51 PM | #4 |
119
Rep 3,325
Drives: E90 335i LCI
i wouldnt think it would be an issue. you will only have problems w/ BMW if something breaks that you have messed with. i would keep it the way it is now it you like it. if something breaks. take it our before you get to the dealer. but the interiors on BMW are pretty good, not much breaking happens there. so chances are your car will be out of warranty before something breaks
03-09-2010, 06:59 PM | #5 |
46
Rep 967
100% depends on the dealer. I got a hard time about my v1 hardwire when I had a gauge cluster issue, so I took it out and low and behold it was on the wrong fuse and was pulling too much current! Lessons learned: make sure it's installed properly, and make it easily removable for dealer visits. Those are the two most important concepts in warranty-period modding.
| PROcede Rev3 | Vishnu Meth | DCI | BMW Perf. Exhaust | AR Coated/Catless | CP-E FMIC | Quaife | |
03-09-2010, 07:37 PM | #6 |
If I don't get reincarnated I'm screwed.
Rep 196
Hi sjg. Sorry to confuse you even further but here are the facts. BMW cannot arbitrarily void the warranty. If you have a problem then they must be able to show that your mod resulted in the failure. Also, even if you did cause a failure, say of the radio, then only the radio warranty would be affected.
There are a lot of unused spaces in the fuse box of a 328. Use one of them. NEVER tap into a wire either to get 12V or ground. Run a hot wire out of a new fuse in the fuse box (they make special fuses with a connector on them just for this purpose), and always run your ground wire to a stand alone ground. In other words, do not share a ground mount with other devices. If your device shorts BMW could claim that your 12v backfed into one of their devices. There is no reason not to hardwire in a GPS or a radar detector, I've done both. You MUST make sure your bf isn't a hack and does the job right. I have seen many laughable wiring jobs done over the years. How some of them did not start a fire is beyond me. |
03-09-2010, 07:40 PM | #7 |
158
Rep 3,158
Yes, it could--not legally per se, but pretty much yes any ways ("warranty denied" -- "what? I'll sue!" -- "good luck with that").
And probably set your car on fire and cause the runflats to bubble. Okay, maybe not that last part.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
03-09-2010, 07:53 PM | #8 | |
Rep 37
03-09-2010, 07:56 PM | #9 |
158
Rep 3,158
BMW would be very hard pressed to find fault with that.
Still, you could end up working with a prick service guy(s)/dealership, whose pleasure is to give you pain. Pardon my French.
--Mark Twain |
03-09-2010, 08:23 PM | #10 |
22
Rep 1,938
03-09-2010, 10:47 PM | #11 |
99
Rep 6,473
It actually depends if you damaged other components while installing it. Otherwise, you should be okay. Just make sure you tap into the right wires.
03-10-2010, 06:49 AM | #12 |
[]D []-[] []_[] []< []\[] []_[] ']['
27
Rep 418
Drives: 335i Convertible/Le Mans Blue/
Sounds unlikely.
2010 E93 335i M LeMans Blue
2001 E 46 330ci Coupe/silver/black/Sunroof 1999 BMW R1200C Cruiser-Ivory & Blue |
03-10-2010, 06:53 AM | #13 |
24
Rep 746
i'd say its a strecht... but can happen...
2009 BMW 335i Sedan / Auto / Paddles / Sport / BMW Assist / Heated seats / JB Matte Black Grill / Tischer First Aid Kit w\Triangle / Tischer Hood Pad / "Custom" rear fog switch <---- SOLD!!!!
03-10-2010, 08:27 AM | #14 |
814
Rep 3,953
Well, you know that sticker on the upper right hand corner of the glass that states you better not add any electronic items to the car....... Also, depends on the dealer and if a BMW zone rep is there to look at the car.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
03-10-2010, 07:34 PM | #15 |
2024 M440i GC (G26)
279
Rep 511
I hardwired both a GPS and a V1 in my E90. I ran a wire from the roof to the 12V aux outlet in the ashtray. As others have mentionned, electronics in these cars are sensitive; better to use the approved electrical circuits.
03-15-2010, 05:20 PM | #16 | |
Rep 117
335I, ZSP, Monaco\Saddle paddles,CA,PRS
ED Drop Off, Zurich, Oct 30, REDELIVERED DEC 29 '06 |
02-11-2015, 05:03 PM | #17 |
22
Rep 86
02-11-2015, 05:54 PM | #18 | |
466
Rep 1,980
This is a perfect example of how to find a thread from 2010 to say something that is utterly WRONG. Why even bother replying to mislead others? Dealers don't have to "prove" anything. It's been well stated above that they will do whatever the hell they want, and you can sue them if you'd like. Sometimes it costs more to go to litigation than swalling it dry. What you said is not what is true in a practical way. And BMW Sticks s freaking sticker right in front of your eyes in the windshield trying to protect itself from the liability... |
