Will LCI headlights fit '07 E93?
11-14-2012, 09:01 PM | #1 |
Rep 82
Hi All,
My wife drives an '07 E93 328i. She saw those new LCI E92s/E93s with headlights that have bright blueish/whiteish angel eyes and lamps. She wants them on her car too. Currently her car has HIDs I think which are like yellowish. So, my question is, will those LCI headlights fit the Pre-LCI models? If so, does it need a trip to the stealership or is an easy DIY? If not, what's the alternative to make her car's headlights look bright white or blue or whatever they are? I drive an E46 so I have very little knowledge about E9Xs. Hence, this question. Thanks in advance. Cheers! Last edited by taskeen21; 11-14-2012 at 09:18 PM.. |
11-14-2012, 09:04 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
no. need bumper and hood.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
11-14-2012, 09:17 PM | #3 |
Rep 82
11-14-2012, 10:21 PM | #4 | |
81
Rep 6,092
easiest thing to do is just get new HID bulbs. move up to 6000k bulbs and you'll get the color you like, still bright and not be "too blue".
11-14-2012, 10:36 PM | #5 | |
Rep 82
Thanks. I think her car has Xenons. I am not sure. Is it the same for Xenons as for HIDs? plug and play? I am so naive when it comes to this headlights, I don't even know what the difference is. |
11-14-2012, 10:41 PM | #6 |
Where'd my VTEC go?
481
Rep 6,067
Xenon and HID are the same thing. I think what you're looking for is LED angel eye bulbs.
11-14-2012, 10:53 PM | #8 |
81
Rep 6,092
if she has an E93 (convertible), then yes, she already has xenons/HID (same thing). if you want these lights to be more "white/blue" then you can just upgrade the HID bulbs to a higher temperature color, like 6000k.
if you're actually referring to the angel eyes (the 4 circles/halos inside the headlight), then yeah you can get LED bulbs like VTECaddict suggested, and that'll help give you the white/blue color for that.
11-14-2012, 10:58 PM | #9 | |
Rep 82
1. Four (4) 6000k HID bulbs 2. Four (4) LED bulbs for the angel eyes Correct? |
11-14-2012, 11:03 PM | #10 |
7445
Rep 10,250
What you're looking to do is to replace the angel eyes and unfortunately they will never look like the newer models because of a poor BMW design. In the 07-09 models the AEs are lit by one bulb on each side, meaning the uneven lighting.
There are no replacements that will look as good. Some guys love their LUX angel eyes, but it still doesn't compare. Your only real choice would be a retrofit, which in the end wouldn't look much like OEM. Do some searching in this lighting section and you'll see what I'm saying. |
11-14-2012, 11:45 PM | #11 | |
81
Rep 6,092
Two (2) 6000k HID bulbs (one for each outer headlight on each side. the inner circle/lights aren't headlights.) Two (2) LED bulbs from like LUX (most popular on this forum)... one bulb lights up both circles per each side for pre-LCI cars. But like the guy above said, it won't be exactly as bright as the LCI e92 angel eyes (they get one per circle/halo). your other option if you HAVE to have them bright and clear, is to get a full LED angel eye setup from like OSS or whoever. LUX is around $250 for a pair... an OSS setup will run you way more though. just fyi.
11-15-2012, 12:28 AM | #12 | |
Rep 82
11-15-2012, 12:35 AM | #13 |
Rep 82
attached pics of what is currently on the car and what she wants
Plus, i have attached pic of what is currently on the car. And the look/brightness she wants is this -
11-15-2012, 03:02 AM | #14 | ||
7445
Rep 10,250
These are the results (or similar) you'll get with anything plug and play and it'll be even less visible in direct sunlight - http://www.e90post.com/forums/showth...gel+eye+thread Sure it won't be yellow-ish like it is now, however it won't be nearly as bright therefore making it a waste of money IMO. If you want to achieve the type of brightness as the OEM 09+ models, you'll need to do an angel eye replacement. If you're interested in that search for "OSS" here. It's not cheap, but it looks the best. |
11-15-2012, 03:06 AM | #15 |
7445
Rep 10,250
BTW, like the poster above mentioned, LUX is the favorite and "best" plug and play replacement here and that still isn't near OEM brightness. Plus it's about $250.
Here's a link showing you some pictures of the LUX angel eye bulbs: http://www.e90post.com/forums/showth...&highlight=lux |
11-15-2012, 03:33 AM | #17 |
7445
Rep 10,250
Not a problem. I've been there and have seen way too many threads with members disappointed in buying plug and play products. I've had two different kits trying to accomplish a whiter angel eye, the first kit I sold after a week and the second I replaced with my OEM bulbs after a few weeks. They're barely visible during the day and that annoyed me.
My advice to you is to learn to live with it or get a full replacement done (if you're handy, you can do it yourself for a fraction of the cost). I've actually started liking my "yellow-ish" angel eyes now with this huge emergence of LED's in just about every new vehicle out there. |
11-15-2012, 03:36 AM | #18 | |
Rep 82
11-15-2012, 03:37 AM | #19 | |
7445
Rep 10,250
I'll dig up some angel eye replacements for you. Two most popular choices here if you want to send the headlights away and have the angel eyes replaced (approx. cost $700-$1000) Are LS3 - http://www.e90post.com/forums/showth...ght=oss&page=5 and OSS - (Great thread that'll show you the comparison of plug and play kits and getting the replacement done) http://www.e90post.com/forums/showth...&highlight=oss One more OSS- (headlight isn't modified too much here so it looks close to OEM) http://www.e90post.com/forums/showth...&highlight=oss If you're handy and want to give a try yourself, here's a DIY - http://www.e90post.com/forums/showth...&highlight=oss Last edited by Game; 11-15-2012 at 03:46 AM.. |
11-15-2012, 03:40 AM | #20 |
Rep 82
11-15-2012, 03:47 AM | #21 | |
7445
Rep 10,250
I left you a few links in my last post. Good luck with whatever you decide. |
