OEM Panic alarm not working after activated through coding
08-02-2011, 12:53 AM | #24 |
43
Rep 437
Drives: 2011 E92 335i AW
Yes, I paid BMW Seattle $210 to reprogram my car. Apparently I have a very old software. It was worth it because everything (idrive) seems a lot smoother and more responsive now.
I had no luck with the DCAN cable though. Basically the alarm wasn't programmed right because the clown nose was blinking fast a number of times before regular blinks (after I locked the car). |
09-03-2012, 12:39 AM | #25 |
47
Rep 427
Is there any way of doing this without using a blank .man file? I dont want to loose all the coding I previously performed.
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
09-03-2012, 04:22 PM | #26 |
47
Rep 427
I was advised to use the NCS Expertmode coding DIY.pdf (sorry, i cant seem to include the link) that eliminates having to utilize a blank man file. Has anyone ever used it?
I followed the NCS Exportmode Coding.pdf recommeded using the Exportmode profile but have a few questions; 1. Per my previous search, several members stated i had to add +K302 to the CAS & NFRM Module. I followed the NCS Expertmode coding DIY.pdf and selected CAS instead of the CIC displayed in the snapshot, is this correct? 2. Once i complete the process, how do i access FA to add +K302? What are the correct steps necessary to do this? Thanks in advance
09-05-2012, 12:26 PM | #27 |
47
Rep 427
ok guys,
I read what feels like hundreds of posts. Many offer conflicting information in addition to confusing pdf write ups. While some advise to use +K302 others say $302. My understand is, $302 is when the vehicle came already equipped with the alarm. +K302 is when it is a retrofit oem alarm installed. Many have also recommened utilizing a "Blank Man File", while the recent consensus is that, using a "Blank Man File" is the incorrect way of doing it. After hours of research and numerous posts, i was referred to utilize the "Using NCS to Change VO.pdf" in the wiki section at http://www.**************/showwiki.p...IYs+for+coding It's an excellent write up, compliments to the author. However, while the process is the same i am changing the VO to code for my alarm. My understanding is that i need to add +K302 in the CAS and NFRM Modules seperately. Because of this I need some clarification on the following; 1. According to the "Using NCS to Change VO.pdf" on the third request to “Choose ECU” it instructs to use “LMA”. I didn’t have an option for “LMA”. As a result I chose “CAS” instead. Is this correct? 2. While doing the process again seperately for “NFRM” using the "Using NCS to Change VO.pdf", I only have the option to select "NFRM" on the first “Choose ECU” request. The second and third time “Choose ECU” requests only have “FRM” not “NFRM”? Any help would be greatly appreciated.
