N55 Starter/alternator power cable replacement
01-12-2021, 06:27 PM | #1 |
Rep 57
The B+ power cable going from the positive battery terminal in the engine bay, that goes to the starter and alternator has fraid and melted in my N55 E90.
I got a new cable, is it possible to get to just the cable connection on the starter and remove that 13mm bolt without removing the intake manifold? |
01-12-2021, 06:54 PM | #2 |
19
Rep 91
Drives: (2007 BMW 335i E92)
Probably, give it a shot and see if it can be done and worse case Ontario you need to pull the intake manifold. Even if you do you probably wont need to remove it completely. The 13mm nut points towards the front of the car so you should have no problem getting a socket on it as long as there's enough space.
You probably won't be able to see what you're doing so just go based off of feel, and make sure to disconnect the battery lmao |
01-12-2021, 07:51 PM | #3 | |
Rep 57
Yea I was going to start pulling things apart to see how much room I can get down there and see how many sockets I lose.
03-10-2022, 09:07 AM | #4 | |
Rep 32
03-10-2022, 10:19 AM | #5 | |
105
Rep 277
If you aint first, your last.
05-01-2024, 07:50 PM | #7 |
11
Rep 49
