09-07-2016, 05:48 AM | #23 | |
58
Rep 273
Drives: 330d touring F31, Z4 35is E89
i don`t use any additonal spacers. Please keep in mind that the 437M have the same offset as for example the 326M but are each 1" wider (9" & 10" x 19"), therefor you have the same effect than with 326M plus 12,7mm spacers on each side/wheel.
Regards Thorsten
Our rides: Skoda Octavia Combi RS TDI DSG / company car // E89 Z4 sDrive 35is / my summer fun toy // F31 330d touring / daily driver of my wife |
06-14-2019, 04:10 PM | #25 |
Z4 35is
60
Rep 270
what is the width of tires?
2011 Z4 E89 35is 2016 435i GC m-sport
06-14-2019, 10:13 PM | #26 |
46
Rep 70
2011 Atacama Yellow Z4 35i FBO
My Car Pics on Flickr |
10-27-2019, 06:11 PM | #27 |
Rep 2
Advice needed on fitment
Question: How much extra space do we have between F/R stock wheel and stock suspension strut? Would a wider wheel that is 26mm closer to suspension strut cause rubbing?
A friend has a set of 9Jx18 ET42 square setup with 235/45 tires to sell and I'm wondering if this setup would work or not. It seems like the front wheels will be 25.7mm closer to suspension struts whereas the rear wheels will be 8.4mm closer and poke out 4.4mm more. In the attached pics, orange lines denote the recommended stock setup whereas green lines denote the 9Jx18 ET42 setup. URLs to actual calculations: Front --> https://www.willtheyfit.com/index.ph...h=9&offset2=42 Rear --> https://www.willtheyfit.com/index.ph...h=9&offset2=42 Got the recommended stock specs from here: https://www.wheel-size.com/size/bmw/...ve35i-usdm-300 Front: 8Jx18 ET29, 225/40ZR18 88W Rear: 8.5Jx18 ET40, 255/35ZR18 90W Last edited by orionx; 10-27-2019 at 06:42 PM.. |
12-26-2020, 08:38 AM | #31 | |
13
Rep 41
02-25-2021, 05:27 PM | #32 |
Rep 5
BBS wheels on black 35is
2015 35is
H&R springs BBS CI R (satin bronze) Michelin Pilot Sport 4S Front:19x8.5 et 35mm. 235x35x19 Rear: 19x9 et 44mm. 265x30x19 No rubbing issues at all. |
06-07-2023, 07:40 PM | #33 | |
Rep 2
Sorry to revive an old post. But I just have to ask, did you do any other modifications to not rub? I just picked up a set of 788M wheels 19x 9J ET 25 and 10J ET40 I want to know if these will rub. I see Fazerfahrer isn’t active anymore but does anyone else have some input? 2011 E89 3.0i N52 stock suspension |
06-08-2023, 03:28 AM | #34 | |
162
Rep 622
Drives: E89 Atacama Yellow 35is
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
08-15-2023, 05:40 PM | #37 |
Rep 20
2009 Z4 35i
Continental sport contact 6 235/35/19 front with 15mm wheel spacers 275/30/19 Rears with 10mm wheel spacers ISC Coilover suspension https://e89.zpost.com/forums/attachm...1&d=1692139002 https://e89.zpost.com/forums/attachm...1&d=1692139002 https://e89.zpost.com/forums/attachm...1&d=1692139002 https://e89.zpost.com/forums/attachm...1&d=1692139002 https://e89.zpost.com/forums/attachm...1&d=1692139002 |
