02-12-2024, 07:36 PM | #24 |
Güdentyte
1164
Rep 1,199
Yes ..
Fender liner OEM part number for the E82 1M Left: 51718051591 Right: 51718051592
CURRENT - 991 GT3 | Future Classic 1M | Model 3 | T4R TRD Pro Lime Rush
SOLD - MB M2 CS | SMB F80 M3 CS | E90 M3 | E90 335i | E46 M3 Vert | E39 M5 | E34 525i |
02-13-2024, 07:45 PM | #25 |
71
Rep 485
My stock wheels with spacers rubbed as well…
So I used a heat gun and a plant piece of wood to re-shape the liner until there was no rub. With a heat gun the liner melts really nicely! And takes any shape you wish. |
02-16-2024, 07:14 AM | #26 |
33
Rep 39
E46M3forRay1164.00 |
02-22-2024, 07:38 PM | #27 |
Güdentyte
1164
Rep 1,199
Got the 1M aligned today and sure feels so much better than before.
Issues I had before alignment: - steering not centered. Points slightly to the left (Fixed) - Car pulls to the right (Fixed) - Front driver tire wears faster than passenger (Fixed with zero toe) - Rear passenger tire slight rub on fender under bumps (Fixed. Added more rear camber) The before alignment measurements were all whacky. It’s all over the place. Shop smooth it all out based on my preference with spirited driving and slightly track setup in case I decide in the future. Ultimate setup was to ensure that no rubbing on 275 front and 295 rear tires.
02-24-2024, 10:46 AM | #29 | |
Güdentyte
1164
Rep 1,199
“You take the blue pill, the story ends. You wake up in your bed and believe whatever you want to believe. You take the red pill, you stay in Wonderland. And I show you how deep the rabbit hole goes.” Also, plate was carried over from my M2CS. I might as well use it. Not a big fan of personalized plates that are too common in the car world or the ones that don't make any sense. lol
02-27-2024, 05:24 AM | #30 |
33
Rep 39
Looking fantastic! The M2 CS looks super awesome as well.
02-27-2024, 10:57 AM | #31 |
38
Rep 26
Subscribed!
Just another 1MClone, 2002 S54 E46 Sedan Bar'd (Sold), 1989 S52 E30 Bar'd (Sold), 1986 M50 E30 (Sold) Ryan GMW Valley Motorwerks |
02-29-2024, 11:00 AM | #32 |
Güdentyte
1164
Rep 1,199
Found some time to take some decent photos before a storm heading our way in NorCal. My goodness, this car is such photogenic. Regardless which photo angle you take, it just looks so damn good.
02-29-2024, 03:05 PM | #33 |
38
Rep 26
Dear lord!!!!
Your 380mm front and rear discs look awesome. I have 380mm F/370mm R and its amazing how much of a difference 10mm makes. Whats the specs on the LM's, I didn't catch it.
02-29-2024, 06:14 PM | #34 | |
Güdentyte
1164
Rep 1,199
19x9.5+32 19x11+25 Modified for reverse face and the way it sits now: 19x9.5+20 (added 12mm spacer to clear Brembo BBK) Final offset +8 19x11+13
Yeee8237.50 |
03-04-2024, 05:47 PM | #36 |
Güdentyte
1164
Rep 1,199
Unfortunately no. One of the best mod installed on the car
arvinz335.50 |
03-09-2024, 07:01 AM | #37 |
1'm Phake
Rep 7
Cool. Love the ride and all the best
I am searching ALL lengths to find one lol.....I am probably going to put a boost gauge and AFR is a floating pod mounted to dashboard but would much rather this sexy cleaner display!!!!!!!!!!!!!!! |
03-18-2024, 07:38 PM | #38 |
Güdentyte
1164
Rep 1,199
Did my first DIY oil change. Since I used to have an E90 335i, it was easy peasy.
seis-speed2435.00 ayao646.00 |
03-19-2024, 10:25 AM | #39 |
16
Rep 29
Very useful and clear video. Thank you for taking the trouble to share !
03-19-2024, 09:52 PM | #40 |
Güdentyte
1164
Rep 1,199
no problem. Probably the 50th time a video made for the 1M on an oil change.
04-04-2024, 07:53 PM | #41 |
Güdentyte
1164
Rep 1,199
Decided to drop my 1M at my detailer to remove the old yellowing PPF, 2 step paint correction, install new PPF and top it off with a full ceramic coating. Been at the shop since Monday and I’m hoping to get it back by tomorrow or early Saturday. I installed the OEM black wheels back. LM wheels has ceramic coating.
Photos below is just the completion removal of the old PPF and wash. Can’t wait to see the paint correction final result. There are many swirl marks all over the paint and old PPF. Just in time for some good weather ahead.
ayao646.00 |
04-28-2024, 12:33 PM | #42 |
Güdentyte
1164
Rep 1,199
Some quick photos with the black M359 wheels before putting the LMs back on. It recently had 3 stage paint correction, ceramic coating and new full front PPF. It's a little bit dirty in here.
7mDr9.00 |
04-29-2024, 10:05 AM | #44 |
Güdentyte
1164
Rep 1,199
it’s just too risky
ayao646.00 |
