08-22-2023, 04:04 PM | #1 |
372
Rep 245
Battery question
Looking to cut power to iDrive controller on grandson’s 2020 M235ix for about 30 minutes. Best to disconnect neg. cable on battery? Are there one or two batteries on this model? And location (locations) of battery?
Thanks in advance for any input. |
10-04-2023, 11:47 PM | #2 |
177
Rep 171
I’m not sure about your model but look in the trunk, lift up the trunk floor and you should see a battery there. If you disconnect that and the battery under the hood the car will have no power
10-11-2023, 07:08 AM | #3 | |
Rep 32
Did you find the locations of the battery/batteries? I need to disconnect mine briefly to change my steering wheel airbag and have the same question as you. Cheers. |
10-11-2023, 07:28 AM | #4 |
15
Rep 46
The main battery is under the hood, behind the engine on the right side - look for a red cap, the battery is under that plastic cover.
10-11-2023, 07:29 AM | #5 |
Rep 32
10-11-2023, 07:33 AM | #6 |
15
Rep 46
See the attachment, if you open that red cap (that's the link to the positive terminal) you can just about see it underneath.
10-11-2023, 07:47 AM | #8 |
15
Rep 46
Accessing it is pretty easy (here's a picture from my car), but to disconnect it you would need to remove those plastic covers I bet - never tried it myself, I just used it to connect my battery maintainer.
10-11-2023, 07:54 AM | #9 |
99
Rep 334
Actually removing the battery is a major task. I watched the BMW Assist guy swap in a new battery on my F40 M135iX (original failed in ~20 months) and it involved removing 8 significant pieces from the engine compartment, plus numerous nuts & bolts. Having seen it done I wouldn't feel relaxed about removing, let alone putting it all back.
10-11-2023, 12:21 PM | #10 | ||
Rep 32
