05-03-2024, 04:52 PM | #24 | |
2455
Rep 5,915
https://f80.bimmerpost.com/forums/sh...69&postcount=2 |
05-03-2024, 05:38 PM | #26 |
2455
Rep 5,915
theweebabySeamus383.50 |
05-04-2024, 12:23 PM | #28 |
502
Rep 696
Drives: 2015 f80 M3
Oh man.
That is aweful. They clearly didn't use the proper tool. Or any tool. (edit: as others have pointed out) Here is a link to an aftermarket updated bushing tool that is similar to the OEM tool I think. https://www.mlperformance.co/product...3-m4-mw90541-t It basically tapers down, squishing the bushing properly into the subframe (special lube is def needed). Properly installed, the bushing is crushed into the subframe compressing/stiffening the foam up just enough to be stiff and quiet at the same time. Its kinda of a cool design. I debated these bushings vs poly and ended up going with poly and a duall bushing plate. It was hands down one of the best mods I did to the car. The upgraded bushing is a good upgrade, but I loved the poly and plate. The car is *so* much more planted. FWIW, the poly bushing install is easier, so maybe that is a good idea for this shop to use to get the car out of there... good luck! josh |
05-04-2024, 03:40 PM | #29 | ||
1481
Rep 1,401
In this thread is the answer to the OP's question https://f80.bimmerpost.com/forums/sh....php?t=2101512 The latest f80 used a metal driveshaft with a poly bushing, and I have not seen a difference between a subframe with a rubber bushing vs a poly bushing, poly can be installed in both and same with rubber Poly bushings on subframe with rubber one Last edited by Track/S; 05-04-2024 at 04:38 PM.. |
05-04-2024, 04:11 PM | #30 |
1481
Rep 1,401
janseny77.50 |
05-05-2024, 10:16 AM | #31 |
Rep 15
Just wanted to say thanks everyone for their help. Gave this Beamer Indy shop a chance but won’t be going back. They are good people, no malice or were trying to trick me.
They just didn’t know how to properly do a poly bushing. I couldn’t fight them too much on it because technically it wasn’t the original part and I wasn’t 100% certain that upgraded bushing would fit. Even though I’ve read posts that the poly bushing retro fits. |
spidy512502.00 |
