Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What headlight seals does bmw use for the front plastic part
      05-09-2024, 01:50 AM   #1
JWeaves13
Australia
Drives: BMW 320d
One of my headlights from my older e90 gets water droplets on the front inside of the headlight when is rains and now as it is becoming winter it also has this water constantly because of the nightly condensation. I am wondering if the headlights seal is just some screws that might need tightening or would it be something like a silicon seal that requires the headlights to be replaced.
      05-09-2024, 10:39 AM   #2
BRG_N54
BRG_N54's Avatar
315
Drives: Green '07 & Arctic '08 335i's
2008 BMW 335i  [0.00]
2007 BMW 335i  [0.00]
Bulb Access Door?
Most of the BMW headlights I know of are glued together, no screws. I might suggest as a first thing to check is the little access door used to replace the bulbs. They are held on with plastic clips that can break or come loose, and cause a leak in the otherwise watertight housing.
If you do find it's not closed completely, wait for a nice hot day so all the moisture is evacuated, then close it up again. If the clips are broken, you might find a replacement door at the local junkyard.
      05-09-2024, 05:27 PM   #3
OMEGA412
OMEGA412's Avatar
12
Drives: BMW 335i Coupe
Get urself some RTV take the headlight out and put a bead around the whole lens. As well as the acsess ports for bulbs. Change all the bulbs before you do this so you dont have to remove the rtv if a bulb goes.
