Damn it, halo rings' tip started to melt..what's wrong!!!
06-23-2006, 10:13 AM | #45 |
86
Rep 1,166
i was thinking if the headlight cant be replaced, i would use a dremel tool to cut away the melted piece by 3-4mm, what you think?
325i Arctics M-Sport, Gray Leather with Alu Trim, ///M DCT Paddleshift, ///M Gear Knob, BBS LM-R 19", Michelin PS2, KW V2, H&R Anti Roll Bars, BMW Performance Air Intake System, 3D Front Lip, ACS Roof Spoiler, OEM Boot Spoiler, Osram 6000K, Brex White Ring, PIAA 6200K HID Fog, PIAA License Plate LED, BMS Powerbox
06-23-2006, 10:26 AM | #47 |
The Ultimate Posting Machine
42
Rep 419
I thought that the "rings" were made of glass and not palsstic????
And using a dremmel to cut away a few mm on the tips is the last thing I would do. I will make them 75x more dimmer. You would also be throwing away your chances of going to the dealer and telling them that it was a manufacture deffect.
06-23-2006, 10:26 AM | #48 |
Moderator
318
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
bimmer325: I was thinking about that from the first time you posted, but I wonder if dremeling it off would leave a finished end that would affect the function of the angel eyes...
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
06-23-2006, 10:35 AM | #50 | |
86
Rep 1,166
06-23-2006, 10:37 AM | #51 |
364
Rep 5,842
Drives: 2006 325xi
Bimmer, do you have other pictures of the tips of the rings? If so post them because i want to take a look at those. It honestly doesnt look burned to me
06-23-2006, 10:38 AM | #52 | |
86
Rep 1,166
to leave a nice surface, i need a precision dremel tool with carbide cutter and use fine grit sander to polish them. since i have brex kit, cutting 2-3mm wont affect too much as long as the tips are not too further in like 1-2cm
06-23-2006, 10:41 AM | #53 | |
86
Rep 1,166
if all cant work, i will buy another set of headlight eventually...bad luck
06-23-2006, 10:47 AM | #54 | |
148
Rep 5,104
06-23-2006, 10:48 AM | #55 | |
86
Rep 1,166
but if you have brex, the angel eyes is brighter in white not OEM yellow (which is more apparent during evening time)
06-23-2006, 10:48 AM | #56 | |
86
Rep 1,166
where is it dude? cant see anything...
06-23-2006, 10:54 AM | #58 | |
148
Rep 5,104
06-23-2006, 10:54 AM | #59 | |
Moderator
497
Rep 27,441
06-23-2006, 10:56 AM | #60 |
86
Rep 1,166
thanks.
is your right headlight halos totally out or they appeared dimmer one than another?
06-23-2006, 11:00 AM | #61 | |
148
Rep 5,104
07-19-2006, 08:02 AM | #62 |
86
Rep 1,166
both my headlight had been replaced on Monday. dealer was slow to process my claim and they even cant notice the difference not until i told them to dismantle the halo. that dealer is suck big time and didnt even want to bother me each time i called up a week after another.
i got fed up and wrote to BMW HQ and screwed them nicely, and they sent my new headlights immediately the 2nd day.
07-19-2006, 08:10 AM | #63 |
Moderator
318
Rep 17,767
So the dealer didn't ask you if you had touched the halo units or anything like that...??
07-19-2006, 08:34 AM | #64 |
56
Rep 617
If you have PMB's you can check your halos in the day time really quick without having to remove everything to get inside the halo housing. If you turn the halos on you wont see the halos themselves light up very well in high sunlight. However if you look at the bottom of the innermost halo up close from the outside of the car; you can see the halo stems before they disappear into the housing and they will appear whatever color PMBs you have. Obviously if the crap that is discussed here is at the tips of the halo stems then the stems themselves would be really dim or not lit up at all. Just a quick way to check your halos that I discovered and thought I'd share.
07-19-2006, 09:10 AM | #65 | |
86
Rep 1,166
07-19-2006, 09:12 AM | #66 | |
86
Rep 1,166
