03-14-2023, 01:44 PM | #1 |
I'm Batman!
3948
Rep 1,477
Horn stopped working
Hey all,
I just noticed that the horn no longer works. I removed the passenger kick panel but the fuse I've seen in some videos is not there. Any ideas? I'm wondering if it's location differs depending on the MY. TIA
S55, 2JZ, M48.00 |
03-15-2023, 10:35 AM | #2 |
258
Rep 358
Drives: 2017 BMW M3 ZCP
Garage List 2001 Honda S2000 [0.00]
2006 Mini Cooper JC ... [0.00] 2020 Audi SQ5 [0.00] 2017 BMW M3 Competi ... [0.00] |
The horns are known to fail. There are two. One on each side of the bumper - can be accessed through the wheel well if you pull off the fender liner. I'd bet you had only one working before, and then second one finally failed. But could also be a fuse if you've recently replaced the horns.
Kilabyte3948.00 |
03-15-2023, 12:38 PM | #3 | |
I'm Batman!
3948
Rep 1,477
S55, 2JZ, M48.00 |
03-16-2023, 07:42 PM | #4 |
39
Rep 119
03-16-2023, 11:48 PM | #5 |
I'm Batman!
3948
Rep 1,477
Not yet, busy with other stuff, was hoping someone would chime in.
S55, 2JZ, M48.00 |
Imboardman38.50 |
04-20-2023, 02:38 PM | #8 |
603
Rep 1,038
My horn went out a few days ago as well. I opened the fuse box in the front passenger footwell and there is no fuse for #14 - Fanfare.
Did anyone figure out where the horn fuse is? Sounds like some cars do not have a fuse in #14, anyone know why? |
papasmurf_m3454.50 |
04-22-2023, 03:29 AM | #9 |
475
Rep 628
Fuse was removed after the LCI.
papasmurf_m3454.50 JibSTir13602.50 |
04-24-2023, 01:30 AM | #10 |
455
Rep 844
is there a fix or just a wear item on these cars?
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+ |
04-24-2023, 03:58 AM | #11 |
475
Rep 628
papasmurf_m3454.50 G35POPPEDMYCHERRY4998.50 |
03-19-2024, 08:35 AM | #12 |
Rep 3
It's frustrating when the horn stops working, isn't it? It's possible that the fuse location might vary depending on the model year. Have you considered checking out resources on bosshorn.com? They might have some helpful tips or even alternative horn options to explore while troubleshooting the issue.
03-19-2024, 09:34 AM | #13 | |
4999
Rep 4,139
lucky its not your water pump when you are out on the road or a window regulator slams your window open in snow or freezing weather or your steering lock fails and your car gets stuck in a underground parking garage with elevator with lifts and no steering control |
