jb4 trigger wire for secondary pump
01-05-2019, 04:45 PM | #1 |
Rep 4
To confirm i have the trigger wire wiring for the second pump correct, could someone please see if this is correct
-Yellow trigger wire goes to terminal 86 on relay -A wire From battery positive to terminal 30 on relay -From terminal 87 on relay to the positive connection on the fuelpump, then is it from the negative connection on pump to the negative terminal on the battery? -From negative terminal on battery to terminal 85 on relay? What im confused about is in the diagram there is a wire from the relay going into pin 7 on the db9 connector on the jb4
Bmw e82 135i 2008 AT
FBO mhd stage 2 e50 (281rwkw) |
