06-26-2019, 09:18 PM | #1 |
E36, E46, E90, E92, F32
97
Rep 368
Window tint triggering auto-dimming on both displays during the day
Hey everyone,
I just had window tint installed all-around and I immediately noticed that it's triggering some sort of auto-dim feature for both my screens. So in the day time, the vehicle thinks it's night time, and it's dimming my displays to where I can barely see either of them. I tried increasing the brightness with the little dial next to the head light switch and that did nothing. I also tried increasing the brightness through the display settings and that also did nothing. Also couldn't find any auto-dim feature in the settings that I could disable. Per the enclosed image, I think the auto-dim sensor is in this black portion next to the speedometer because when I put my hand over it, it dims everything and when I take my hand off, everything brightens up again. Do you know if there's any way to turn off this auto-dim feature for the displays whether it be through a setting or coding? I imagine other owners who are tinting their windows are having the same issue? Thanks in advance, guys!
06-26-2019, 09:56 PM | #2 |
102
Rep 103
I actually just got tint also a few days ago, and have not noticed any issue with the screens like what you are seeing. Though my tint is 50% in the front windows (thank you, dumb Virginia laws). It's F1 Pinnacle tint, in case that could be a relevant data point.
But I didn't realize the sensor for the auto-dim is in that area you highlighted...I'll play around with it on my commute tomorrow and see if I do notice any peculiar activity. |
06-26-2019, 10:24 PM | #3 |
318
Rep 387
@dpod25 Where did you get your tint done? I am in Arlington and taking delivery in about a month, I'm currently leaning towards TintFX with Suntek CIR.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
06-26-2019, 10:35 PM | #4 | |
97
Rep 368
Thanks man, let me know what you discover tomorrow during your commute 👍 |
06-27-2019, 01:37 AM | #5 |
134
Rep 259
I have noticed the same issue with my car. Here in downunder Australia, we re allowed to go up to 65% tint. I hope the daytime dimming feature can be coded out. Why can't they have one brightness for daytime and one for nighttime (when headlights are on) - like cars used to!?
06-27-2019, 08:17 AM | #8 |
208
Rep 547
When the screens dim is your headlights coming on too? I know with the F30s at least you can code the headlights to come on earlier or later than normal. Maybe setting it to later will make it less sensitive? Hopefully we get coding on the G20 soon.
Current: 2020 M340xi Previous: 2016 340xi |
Patgilm182.00 |
06-27-2019, 08:31 AM | #9 |
342
Rep 632
Drives: 2019 X740i
I have the same issue, but in our X7. We can tint very dark here in Florida, so I'm sure that's the problem. It happens far less frequently now than it did when we first got it done, which is also odd...
06-27-2019, 09:01 PM | #10 | |
102
Rep 103
To confirm, I did try to cover the area you highlighted and the screen remained bright. To make the results more conclusive, it was bright and sunny outside during my AM commute while I drove back home in an afternoon thunderstorm. With the thunderstorm, my headlights then did switch on and hence the brightness of both screens did indeed go down. But increasing the brightness dial brought them back to full brightness. I'm sorry if that's not the result you were hoping I'd have. Perhaps you could double-check the screen brightness with your headlights on vs off. Also, maybe try testing both outside and in a parking garage somewhere. Hope you get this issue resolved, definitely keep us posted! |
Spenc919.00 |
06-27-2019, 09:05 PM | #11 |
102
Rep 103
LA Tint in Sterling. It might be a bit of a drive for you, but I think it's worth it. Geoff, the owner, and his team have done top-notch work with both of my cars. I paid around $400 for F1 Pinnacle on all four doors and the rear window.
06-27-2019, 10:15 PM | #12 | |
97
Rep 368
Hey dpod, thanks so much for the detailed write-up. I'm glad you're not encountering the same issue as I am! Going to take it into the dealer tomorrow and see what they say. Will report back whenever I figure this out! 👍 |
dpod25102.00 |
07-01-2019, 02:31 AM | #13 |
97
Rep 368
The dealership says that the auto-dim feature of both my displays can't be coded out otherwise it'll throw up error codes.
My tint is actually 15% all-around, not 60% (not sure where I got that number from). So it's pretty dark. Going to try and lighten it up to 30% or so and see what that does.
07-01-2019, 02:32 AM | #14 |
97
Rep 368
Can I ask what tint % you got?
07-01-2019, 02:33 AM | #15 |
97
Rep 368
Can I ask what % you got done?
07-02-2019, 01:02 PM | #20 | |
1566
Rep 1,412
07-03-2019, 12:48 AM | #21 |
97
Rep 368
Haha yea, would definitely be an interesting convo. Damn, sounds brutal in NV!
07-03-2019, 10:58 AM | #22 |
93
Rep 124
Drives: 2020 M340i TB II
I guess I won't be tinting my front windows anymore. I would have to have 5% in the front just to match the rear windows.
