Coolant Hose Replacement N52
01-18-2014, 12:02 PM | #1 |
17467
Rep 18,817
This is a DIY for removal and replacement of the entire nine (9) hose set for the N52 engine in a 2006 325i with a manual transmission; an automatic will use some different hoses (see post #21 from Smassy321). I would expect that this is applicable to both the 325i and 330i of 2006 model year and probably the 328i from 2007 on. The hose set I replaced was for a car without auxiliary heating; which I don’t think was offered as standard equipment nor as an option for USA market cars. There are a few more hoses in the set for cars with auxiliary heating, but the basic procedure is the same.
That said, if you do not plan on keeping your car for a long time and high mileage, you probably do not need to replace the hoses as preventative maintenance. I replaced my hoses at 7 ½ years and 236,000 miles and my hoses were a bit dry on the outside without any cracks or ozone damage and still pliable, and inside they all still looked very good. This is not a DIY for a novice do-it-yourselfer. You need a lot of special tools and ideally have access to a two-post car lift. In my opinion it would be very difficult to do this DIY without the aid of a lift (you have to raise the car too many times); however, if you have time and are a masochist, you can probably do it without a lift. A note on tools: You need a good set of automotive repair tools with compete sets of ¼-drive, 3/8-drive and ½ drive sockets and extensions and flex-joints, torx sockets, E-Torx sockets, and metric wrenches. I’ve tried to list the special tools not common to what a normal DIY’er may have in his tool box. Thanks to scotty_miller for some o-ring info. Details in file below. Last edited by Efthreeoh; 05-10-2023 at 05:42 AM.. |
01-18-2014, 02:57 PM | #2 |
261
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Some job there, I would never have imagined so many hoses, what a pain.
I'm having the water pump done this week at 138,500 miles (I know, barely broken in ) and had my mechanic order the upper and lower hose to replace because I figured after all this time they would need to be done. Did the radiator look ok? I never would have figured all those hoses and radiator would last so long on a bmw, obviously a tremendous upgrade over previous generations.
StradaRedlands5021.50 |
01-18-2014, 03:08 PM | #3 | |
17467
Rep 18,817
01-18-2014, 10:39 PM | #4 |
261
Rep 1,794
Nice, I saw the shroud of Berlin haha. Turner has a used n52 rad for cheap Im glad i didnt buy it.
Thanks again for the post |
01-19-2014, 11:33 AM | #5 |
17467
Rep 18,817
You had left me a visitor message, so I could respond back directly (guess I should have left it on your page). Anyway, I'm bit concerned that I flexed the plastic side-tank a bit on the left side around the upper hose bib. The BMW hose connector design is really over engineered and unnecessary IMO.
01-20-2014, 10:12 AM | #6 | |
261
Rep 1,794
Has your car seen much road salt? I bought my car from Texas used when it was 3 yr old, and it has had 5 winters since then. We have a great car was company here that has a monthly pass that allows you to wash as much as you want, and has an under spray that I use quite often, but the road salt in Buffalo has to have an effect on these parts regardless.
01-20-2014, 08:28 PM | #7 | |
17467
Rep 18,817
12-11-2016, 06:18 AM | #8 |
17467
Rep 18,817
I'm bumping this thread to update on the radiator longevity discussion. If you read the thread, I replaced all the hoses at 236,000 miles, but did not replace the radiator. Now, 80,000 miles later at 315,000 miles the radiator is still leak free. That's two more hot summer's of driving in stop and go traffic.
Just some data for the community.
cliffschum15.50 StradaRedlands5021.50 |
12-11-2016, 08:57 PM | #9 |
395
Rep 662
Thanks for the update. I have been contemplating replacing all the hoses prior to the spring/summer months. Seems like a good (but tedious) winter project to do in ye ole garage.
08-18-2018, 01:18 PM | #10 |
13
Rep 5
2008 328i, manual hoses, pump, and thermostat replacement
I just replaced all the hoses, water pump, and thermostat on my 2008 328i, 6 speed manual. The car has 130,000 trouble free miles. I did this as a preventative measure. Efthreeoh's excellent write up along with the two BavAuto water pump and thermostat replacement YouTube videos pretty much tell you everything you need to know. All of these are packed with extremely helpful tips. I did not find this to be a difficult job. It's a lot of work and not a good first job for a newbie but all the tasks are straightforward. I do have a lift and that did make doing the job much easier and more comfortable.
Here is information that others might find helpful. - The temp sensor on my car is mounted to the OFH and is easily accessible. So there is no synergy to replacing it at hose changing time. - As did Efthreeoh, I found disconnecting the large BMW clamp connectors from the radiator to be the hardest task. Take his precautionary advice and place all baseball bats and golf clubs in protective custody until these hoses have been removed. I did not remove the radiator. As others have advised, I kept pulling (and pulling) with a slight circular motion. None of these clamps released suddenly. If you watched carefully you could see your (very slow) progress. After the connector housing had backed off about a mm or so then I could find a way to carefully pry with a small screw driver and things progressed quickly with less effort from there. Curiously each of the male portions of these connectors were designed quite differently so the prying method varied with each one. - When going after the top water pump mounting bolt DON'T accidentally remove its much more visible, immediately next door, air conditioner mounting bolt neighbor. This too is a stretch bolt which your dealer won't likely have in stock. The water pump bolt head is located in the harder to see, recessed pocket right next door. - I was able to remove (and replace) the lower heater core hose (228-01) totally from the top. But I could not have done so without knowing the spring clip is oriented and removed from the bottom side of the hose. Just one of the many useful gems of information in Efthreeoh's write up. - On my car the OFH to thermostat hose (427-07) is connected to the OFH with only two bolts. - Use silicone plumber's grease to lubricate the o-rings inside the BMW clamp connectors before assembling. The big box hardware stores all carry this. Be sure to buy the silicone grease, not the traditional plumbers' grease. The BavAuto video mentions this tip but at a point where you probably have already assembled a number of the connectors. - Instead of replacing the entire Engine Block to Water Pump metal-tube/rubber stock part (283-03) I just replaced the rubber portion using the Rein CHE0497 part. The original hose is clipped to the metal tube with a spring clamp. The clamp does not have the typical ears but I had no problem removing it using a pair of channel lock pliers. There is plenty of room to use a Dremel to cut off the clamp should someone prefer that removal method. The Rein hose comes with a traditional spring clamp with ears that stick up away from the hose. Be sure to orient the ears as far (rotationally) toward the back of the car as possible. At first I didn't pay attention to its orientation but I found the ears came uncomfortably close to rubbing against one of the large hoses connected to the water pump and thermostat assembly below. So I took things apart again and reoriented the clamp to provide plenty of clearance. - When reassembling, pay attention to the BavAuto video hose clamp clocking instructions. Your life will be easier for doing so. Post work thoughts: Had I not mistakenly removed the wrong bolt (which I had to wait for my dealer to order) I could have completed this in one long day. All of my original hoses and plastic tubes looked perfectly fine. Modern hoses like these are made from EPDM rubber, making for a hose that is far superior and longer lasting than those of yesteryear. Here are the part numbers for the pump, thermostat, and hoses I used. All were purchased through FCP Euro and I chose the OEM equivalent, where available, instead of genuine BMW. 11517586925 - Water Pump 11537549476 - Thermostat Rein CHE0497 - 283-03 - Engine Block to Water Pump Hose in lieu of 283-03 complete replacement 11537521049 - 472-01 - Thermostat to Pump Hose 11537545890 - 472-07 - OFH to Thermostat Hose 17127531579 - 472-17 - Upper Radiator Hose 17127618510 - 472-20 - Expansion Tank Vent Hose 17127564478 - 472-18 - Lower Radiator Hose 64219178427 - 228-01 - Heater Core Lower Hose 64216951946 - 228-02 - Heater Core Upper Hose 17127548223 - 472-23 - Expansion Tank Heater Core Thermostat Hose-Pipe |
Efthreeoh17466.50 StradaRedlands5021.50 |
01-13-2019, 09:19 AM | #11 | |
401
Rep 1,579
Great write up. Thanks |
01-13-2019, 09:33 AM | #12 | |
17467
Rep 18,817
The reservoir tank is original.
03-30-2019, 08:59 PM | #13 |
54
Rep 74
Happy to find this thread as my lower heater core hose has sprung a leak (I think, at least. I haven't pulled the airbox to verify)
Last round of maintenance I noticed it had developed a sizable bulge in the side so I promptly sleeved it with another hose, lol. Figured if I could get a few miles out of it I would. Time to drain the coolant. Thanks for posting the DIY
I like broken things.
Efthreeoh17466.50 |
03-31-2019, 06:17 AM | #14 | |
401
Rep 1,579
03-31-2019, 06:43 AM | #15 | |
54
Rep 74
When I bought the car, the front engine bay and block was ENCASED in a 1/4" layer of oil and sludge. No doubt it hastened or caused the bulge. The brake-kleen I used to clean some of it up probably didn't help either.
04-12-2019, 03:09 PM | #16 |
54
Rep 74
Just swwapped out the lower heater core hose. Did it on jackstands. Access from the bottom to release the clip was a no go, because iX hardware was in the way. Looking from below gave me a pretty good idea of what I was up against so i used an articulating mirror and tiny screwdriver and popped it from the top.
Having done a cowl delete (using Berger? cabin filters) meant I had more room to get my hands in there. I had to pull the airbox and tubing, and temporarily relocate the brake reservoir. I also pulled the brake reservoir bracket to get a little more wiggle room. Once I popped the clip, the hose (as OP mentioned) came off pretty easily. I'm hoping that it was indeed the lower hose that was leaking. Guess I'll find out soon. Thanks again for taking the time to put together the DIY, OP. It made the swap easier for me.
Efthreeoh17466.50 |
05-14-2019, 06:42 PM | #17 |
54
Rep 74
A month later and I'm still losing coolant in the same general area (puddles on top of bellypan, under airbox), so I just replaced the Radiator Return Hose, pretty straight forward. Removing and temporarily relocating the brake fluid reservoir and zip tying some other hoses aside made access room to make the job way easier. Put about 50 miles on it today and so far no more leaking. Fingers crossed. I'm sure I'll be back later this year to swap out some more of the original hoses.
bluewater328626.50 |
05-18-2019, 05:32 PM | #18 |
24
Rep 75
I would be grateful for a little help. What is the P/N of the hose in Dwg 472 that goes from 17 to the firewall? I can't seem to find it in any of the diagrams on Real OEM... I am assuming it has a plastic connector (female) that mates to the male end on 17? Is there some sort of an O-ring in there? Replacing this hose looks like it would be a real pain since it runs through the whole engine bay...
My '06 325i is leaking from the connection between 17 and this long hose. It's also leaking from a small crack on top of the radiator outlet that connects to 17. That part is plastic and has cracked along the mold seam. So, <sigh....> need to replace the radiator, 17, and, potentially, the long hose to the firewall. Probably should do the water pump while I am at it. The current one went in at 88K back in 2012... Thank you! |
05-18-2019, 05:44 PM | #19 |
24
Rep 75
Duh... Never mind. Efthreeoh answers my question in his DIY. 228-01 (64219178427) Heater Supply Hose is the one I was looking for. Sure was not obvious from the diagrams..., at least to me.
Thank you, Efthreeoh! |
05-24-2019, 10:42 AM | #20 |
11
Rep 93
Drives: 2006 BMW 325i
great write up, thanks Efthreeoh! saving my ass again haha
06-01-2019, 01:14 PM | #21 |
401
Rep 1,579
Thanks to Efthreeoh for the DIY. I just did all the hoses, radiator and tank on my 06 325i. I am only at 120k miles but my daughter is taking the car to college in AZ so I wanted everything to be new. Water pump and thermostat were changed a few years ago.
The only hoses that were in bad shape were the two that go to the oil filter housing area. Both had good hose but bad plastic on the inside. They fell apart when I tried to pull them out. So if you want to stay on a budget, just do those 2 (I spent close to $600 for everything). Next worse were my heater hoses that were soft under the air box area. The rest were fine as was the radiator and tank. All were 14 years old. Mine car is an automatic so the parts list is slightly different. When compared to the PDF parts list, there are 2 different hoses and 2 additional hoses. 2 different hoses 17127548223 is replaced with 17127548224. It has an extra hose on the assembly going to the trans oil cooler. 11537535829 is replaced with 11537516414. It has an extra fitting for 17127540020 below. 2 additional hoses. 17117524710 - trans oil cooler - goes between the trans oil cooler and the radiator. 17127540020 - low-temperature cooling module - goes between 11537516414 and the radiator. And finally, this is the o-ring I used for the temp sensor. BMW does not sell these. https://www.ecstuning.com/b-uro-part...21433077s~uro/ |
Efthreeoh17466.50 |
06-01-2019, 08:10 PM | #22 | |
17467
Rep 18,817
