My CIC Combox 6FL retrofit log (and DIY focused on coding)
09-26-2019, 01:07 PM | #23 |
98
Rep 121
That's some awful packaging! Seller should definitely pay for return shipping and give a full refund. I had to return my first CIC unit because the seller had ripped off the AM/FM jack so no cable could be connected. Sigh. |
09-26-2019, 05:40 PM | #24 | |
153
Rep 444
My first CIC was damaged on arrival aswell. Fm/am pin was damaged. Last edited by TiAgAu; 11-15-2019 at 06:26 AM.. |
10-06-2019, 04:49 AM | #25 |
64
Rep 760
Drives: E82 135i & F80 M3
Happy to report it all worked out!
eBay seller had a second part out vehicle and sent me an 2009 CIC screen, and the USB + CIC video cable! Also happy to report that your guide was 100% SPOT ON. Every step of the way you detailed completing a full 2007 E90 CCC to an 2013 CIC + combox retrofit. THANK YOU for writing this extremely detailed DIY. It was exactly what this community needed as I had planned to do this retrofit with the various mix mash of threads out there, but yours is 100% complete. I will also save PDF versions of the web links he mentioned so they will forever be archived. |
10-06-2019, 01:13 PM | #27 |
186
Rep 927
Not to thread hijack guys but I'm having an issue with my combox retrofit. I get no Bluetooth phone nor media. When I select the telephone option all it shows is please wait. I also scanned combox for codes with protool and got this error about microphone 1. Would swapping out the mic restore my Bluetooth. I've searched and read about people having mic issues as well but usually they can still play music via Bluetooth and make calls just that people can't hear them. Any help? Hopefully it's not my combox that's bad
10-06-2019, 02:40 PM | #28 |
98
Rep 121
I’m not familiar with protocol, but it says CCC no error found. Do you have a CCC or CIC? Combox is only compatible with CIC.
What car do you have? What equipment did it come with? Are you retrofitting both CIC and combox, or only combox? Did you default code both the CIC and combox together after retrofitting and updating the FA/VO? |
10-06-2019, 04:57 PM | #29 | |
186
Rep 927
10-06-2019, 06:07 PM | #30 |
98
Rep 121
Sounds like your CIC isn’t coded correctly, consider using NCS expert to do the coding. Voice commands and Bluetooth phone calls use two different mics. The the voice commands microphone is routed directly to the CIC headunit and the telephone mic is routed to the combox (or TCU). Ergo, if your voice commands stopped working, it’s not the combox.
10-06-2019, 06:25 PM | #31 | |
186
Rep 927
10-06-2019, 11:28 PM | #32 |
98
Rep 121
Switching from the TCU to the combox changed a lot of settings in my CIC. Here are all the changes that occurred after I removed $639 and added $644 and $6VC:
Code:
ASSIST nicht_aktiv ASSIST_INITIALIZATION nicht_aktiv ASSIST_REMOTE_HVAC aktiv ASSIST_VEHICLEFINDER_SHOW aktiv CDMM_BLUETOOTH_AUDIO aktiv PHONE_SMS aktiv SHUTDOWN_DELAY_TIMER_2 wert_00 ASSIST_ECALL_CALL_HANGUP aktiv DAYDRIVING_LIGHT perm_off NAVI_FUELSTOP_PROPOSAL aktiv TELEMATIC_INSTANCE_ID instanceid_0x01 MUTE_BUTTON aktiv BT_PHONE_INSTANCE_ID wert_02 FUNCTIONALITY_VIEWER aktiv NAD_PHONE_INSTANCE_ID wert_01 CONNECTIVITY_SYSTEM_VER ecu_sw_vid DATACOM_INTERFACE combox HDD_ACCESS_VIA_ETHERNET aktiv SDARS_REPLAY_AUTOMATIC aktiv CDMM_USB_COVER_ART aktiv DATACOM_TRANSFER mamac MICROPHONE_0A no_microphone ECALL_INSTANCE_ID_0A wert_01 MACRO_PIM aktiv PIM_CROSS_USE aktiv PHONE_TYPE_C0B combox PIM_DRIVING_TEXT_LENGTH up_to_three_lines MESSAGE_FILTER aktiv ONE_SHOT_DEST_INPUT_C0D aktiv SECONDARY_HFP aktiv AUDIO_OFFSET aktiv SLEEPDELAY_CLAMP30B_MIN_2 wert_90 |
SlimE92185.50 |
10-08-2019, 08:52 AM | #33 | |
186
Rep 927
10-08-2019, 11:52 AM | #34 |
98
Rep 121
10-08-2019, 12:01 PM | #35 | |
186
Rep 927
I Switched Datacom interface from tcu to combox. Bluetooth audio was not enabled I set it to enable, and phone type c0b was set to tcu I set it to combox |
10-08-2019, 01:31 PM | #36 |
45
Rep 193
I have to say Im impressed, I did this work about 3 years ago and started writing a comprehensive DIY and never finished as too many questions came up about how to use FSTool/CarServer and felt that perhaps it was better to leave pandora's box closed on that one, props for putting the info out there though.
Can confirm 100% that this method (at least the certificate creation and import) works and reads/scans/codes like OEM...been that way for me for 3 years at this point. Its nice to see the tools have gotten a little easier to find/work with at least |
10-08-2019, 02:53 PM | #37 | |
98
Rep 121
10-09-2019, 07:51 AM | #38 |
Rep 21
Maybe a dumb question here as I'm looking into a CIC/Combox retrofit and there is so much info out there on this. But one thing I could not clarify, many have said go with a newer 2012+ CIC head unit. Is this head unit from the F base model 3 series? Exception being the E92 Coupe going to 2012? Thanks just want to seek some clarity as I source parts.
10-09-2019, 09:55 AM | #39 | |
98
Rep 121
10-10-2019, 12:57 AM | #40 |
98
Rep 121
Forgot to respond to this, glad you sorted it out! Consider reporting your experience to the developers of ProTool, since it seems that default coding to a new VO didn’t work for you.
10-10-2019, 03:52 PM | #41 | |
186
Rep 927
10-12-2019, 10:42 AM | #42 | |
186
Rep 927
11-01-2019, 02:41 PM | #43 |
13
Rep 78
What did you end up doing on which module? using protool? I have the same issues you described. The only thing I am getting by retrofitting the combox is I can play music through usb from my phone
11-01-2019, 06:28 PM | #44 | |
186
Rep 927
