      01-10-2023, 01:59 AM   #155
DanyM
Drives: F10,F40
Dear all, I just finished with Bimmercode coding F40, video in motion, start/stop. Did someone success to put M logo on instrument cluster?
      01-10-2023, 11:37 AM   #156
Sans_S1
Drives: Bmw F40
Yes, with BimmerCode standar > Display options instrument cluster > Layout > M Sport
      01-12-2023, 02:34 PM   #157
M5ZRH
122
Drives: M5
After reading all this post:
Is it possible to code the M Instrument cluster and add the correct red line for the M135i engine ?
And any chance to change the scale of the speedo to go to 260 km/h instead of 330 to be more legible ?
In expert mode ?
Thank you
      01-20-2023, 06:02 AM   #158
Sans_S1
Drives: Bmw F40
Originally Posted by Erebor View Post
I have and this is exactly, what is asked for here. That works.
Hi!
Can you post a video/image of the coding working?
I just tried it with BimmerCode > Lighting > Exterior lighting switch-off but no result. It does the coding but it doesn't work for my Bmw F40.
I still can't turn off the lights with engine running.
Is it necessary to modify something in the lighting also in the Idrive? Thanks!
      01-20-2023, 03:18 PM   #159
Erebor
Erebor's Avatar
Switzerland
1130
Drives: M4 Competition (G82)
Originally Posted by Sans_S1 View Post
Hi!
Once my F40 arrives I will proceed to code it again and provide you with some pics.
2022 G82 M4 Competition xDrive in indiv. Sunset Orange
Incoming: 2023 F40 M135i xDrive in indiv. Tansanite Blue
      01-21-2023, 04:58 AM   #160
Sans_S1
Drives: Bmw F40
ok! Thanks!
      01-24-2023, 06:21 AM   #161
Manboy
Manboy's Avatar
Sweden
440
Drives: 2020 M135i Misano Blue
I managed so solve an issue I had and wanted to share.
if you're in manual mode, you see your current gear in the Combi as "M4" for example but this quickly goes away and is replaced by recommended gear like "4>5" and the numbers turn small.
If you want it to only show current gear go to bimmercode:
Instrument cluster / Expert mode / SPA_KOMBISELECT_DISABLE
Change this from "active" to nicht active"
Erebor1130.00
      01-25-2023, 07:45 AM   #162
Sans_S1
Drives: Bmw F40
if you're in manual mode, you see you current gear in the Combi "M4" for example but this quickly goes away and is replaced by recommended gear like "4>5" and the numbers turn small.
Thanks! It is appreciated that there are colleagues who investigate and share F40 codings. Especially for people who are not specialists in coding
Manboy440.00
      02-06-2023, 05:34 AM   #163
Sans_S1
Drives: Bmw F40
Hi Manboy
Did you recode the automatic lights off when the engine is running?
Did it work for you with BimmerCode? It still doesn't work for me.
Could you tell me how you did the coding or tutorial?
Thank you!
      02-10-2023, 02:32 PM   #164
Manboy
Manboy's Avatar
Sweden
440
Hi Manboy
Thank you!
Hi,
Yes, it worked fine. There is an option in the basic meny in "Body Domain Controller". just scroll down and find "Exterior lighting switch-off allowed" and choose Yes. That is how I did it. I should work for you as well. Let me know if it doesn't and I'll have another look in Bimmercode while it is connected to my car.
      02-14-2023, 08:24 AM   #165
a8rt
Drives: BMW F40 118i
Does Sport Plus really work for the F40 118i?
      02-14-2023, 11:34 AM   #166
cjn
99
Drives: 2021 F40 M135iX
An interesting debate. Some people swear that the 'enhanced' driving modes for F40 cars make a difference, while others are convinced that it's all in the mind. Probably best to try it and decide for yourself, with some objective assessment if possible.
      02-14-2023, 04:48 PM   #167
Sans_S1
Drives: Bmw F40
Hi,
Okay.
This week I try the coding again following your instructions. I hope it works
Thank you!
      02-15-2023, 12:37 AM   #168
Manboy
Manboy's Avatar
Sweden
440
I was wondering this too, so I tried it and it did nothing in my car.
      03-03-2023, 04:26 AM   #169
Sans_S1
Drives: Bmw F40
Hi,
Hi Manboy
I changed the OBDII adapter and now with Bimmercode if I can activate the coding for lights off while running. It works perfectly, thanks!
      03-03-2023, 06:43 AM   #170
Manboy
Manboy's Avatar
Sweden
440
Hi Manboy
Great to hear!
      04-03-2023, 03:25 AM   #171
a8rt
Does anyone know how to change the D shown in the instrument cluster during normal driving mode to always show "D1/D2/D3"?
I would like to know my gears when i am driving in comfort/sport auto mode.
      12-07-2023, 09:36 AM   #172
sjohn22
Drives: .
There are 2 main things i was looking to code, but im not sure if its possible.
1- Unlock all doors after opening the drivers door from the inside. Its a bit of a pain having to go get the keys again if i want to take something out of the back seats or trunk.
2- remote start, mostly for climate control.
      12-07-2023, 10:19 AM   #173
cjn
99
1. Don't you have lock & unlock buttons, also a trunk unlock button, on the driver's door?
2. Remote engine start is likely to be not allowed, depending on where you are. In iDrive you can set the ventilation to start at a defined time.
CAR/Settings/Climate control/Auxiliary ventilation/Departure plan
I may not have defined this exactly, but that should be close enough.
      12-07-2023, 10:41 AM   #174
sjohn22
Drives: .
Thank you for your reply and help!
About the 1., the doors, i do have those buttons - i can unlock all doors and boot from there. But im used to on all cars, even bmws before that i had driven for a while, they would unlock all doors after i opened the drivers door. For example, exiting the car by the drivers door and then trying to take something from the back seats. As it is now, i need to keep the key in hand and press the unlock button on the key, even though i just exited the car.
the #2, i did some research and as it now, this only heats the car using remaining heat from the engine. But if the car has been parked overnight, the engine will not have heat to provide to it.
I have programmed the hours on idrive, and when i get to the car i can still hear the fans but no heat is inside or coming from them.
      12-07-2023, 04:06 PM   #175
cjn
99
1. If you set the unlock action in iDrive to unlock all doors with the remote, rather than just the driver's door, does this change things? Driver's door only is an obvious security measure to stop potential scumbags jumping in as soon as the car's unlocked.
2, I think this is more of a hot climate option, to ventilate the car before you get in. Obviously it can't conjure up heating or air conditioning from nowhere.
      02-26-2024, 04:24 AM   #176
Futingo
Drives: BMW 128ti
Originally Posted by dedons View Post
Hello, I codified the instrument panel of my f40 with bimmercode, I put the M series, but I don't know why the 3.0 csl writing appears to me. Has this happened to anyone else?
I am the same, I am not able to change the logo in that configuration, is there someone who knows how to change the logo?
