01-18-2024, 09:27 PM | #23 |
460
Rep 2,072
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
legit instructions too
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
bertocolon87.50 |
01-19-2024, 11:29 PM | #24 |
460
Rep 2,072
received the unit, looks good, going to install
01-21-2024, 01:04 AM | #25 |
460
Rep 2,072
took everything apart like a fool and realized there were no instructions included. Luckily disassembly and reassembly is like 15-20 mins to get all the trim and screws out so all good. Waiting for the "tech specialist" at bimmerplug to send me the directions on Monday. Install SHOULD be straightforward and I probably don't even need the directions, but Id rather not have to do it 2-3 times to get it right so I'm telling my impatient self to fucking waitttttt lol
01-21-2024, 01:09 AM | #26 |
460
Rep 2,072
im thinking none of the wiring is needed if you have an iPhone. think its just if you want to add android capability to the unit but not 100%
02-01-2024, 05:05 PM | #27 | |
47
Rep 61
Drives: 2016 M3, 2022 X3 M40i
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 10" will work fine. There is a ton of support info on the F30 forum. If you want more customization, check out the follow links. https://github.com/Snaggly/KSW-ToolKit https://github.com/KswCarProject |
02-02-2024, 12:40 AM | #28 |
494
Rep 258
I have the 10” X5 touch screen the one that Tommy L garage did. I upgrade my 4 nbt to an EVO. I have idrive 6 with full screen car play. Was pricey but worth every penny. 90% of people that look at my interior don’t know it’s not factory.
jaylazy2020264.00 |
02-02-2024, 12:46 AM | #29 |
460
Rep 2,072
10.25” fits nice
lawnmower35147.00 |
02-10-2024, 01:27 PM | #31 |
460
Rep 2,072
When it gets here
02-12-2024, 08:46 PM | #33 | |
154
Rep 419
But I look forward to seeing how it turns out for you … maybe you’ll change my mind!
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive |
02-13-2024, 08:26 PM | #35 |
154
Rep 419
I’m sure it will look awesome and then I’ll want to do it!
NORAGRETS459.50 |
02-14-2024, 10:19 AM | #36 |
460
Rep 2,072
The 10.25 fits without cutting or modifying
02-14-2024, 10:20 AM | #37 | |
460
Rep 2,072
02-14-2024, 04:02 PM | #38 |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
I did a 10.25" G30 screen years ago. No cutting required, but did take a little creativity (and I've since refined a better back cover).
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 02-17-2024 at 03:16 PM.. |
NORAGRETS459.50 |
02-16-2024, 09:32 AM | #39 |
127
Rep 259
Fitted and coded and looked really good! This was an LG screen which BMW changed to after 2018 and resolution looks even better as well! Early 2018 or late 17 G series screen is not LG.
In terms of trapezoid it’s better than square as gives a gap to see out of the windshield between the Guage cluster and screen easier and matches the shape of the AC controller inverse. Was plug and play with bimmertech adaptor 😅 |
02-16-2024, 11:42 AM | #40 | |
4024
Rep 3,540
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
02-16-2024, 10:08 PM | #41 | |
154
Rep 419
02-17-2024, 03:38 AM | #42 | |
264
Rep 644
Do you get used to the slightly obstructed view? I had a G30 before my F82 so this would be ideal |
02-17-2024, 09:20 AM | #43 |
127
Rep 259
Thanks as did see the square screen from F15 with the silver trim around did not like as just looked like an afterthought and visability is blocked on them and sits slightly further back. Also it’s not plug and play fit which I did not want to cut anything.
This screen with the kit sits slightly further forward which makes it slightly easier to touch it and gap between cluster and screen is bit bigger due to shape. Screen was from EBay but had to go hunting around as BMW changed manufacture from 2019 to LG anything older is made in Thailand by another company KYOCERA and screens seems to be less bright and some issues were reported with flickering. Alpine made the 8.8 screens for BMW. |
02-17-2024, 08:58 PM | #44 | |
460
Rep 2,072
