KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
08-09-2011, 12:55 PM | #45 |
221
Rep 2,339
Car: 09 E90
Wheels w/ Offsets: HRE P40 - (F) 20x9 +28, (R) 20x10.5 +28 Spacers: None Tires / Miles: Vredestein - (F) 255/30/20, (R) 285/30/20; New Tires Suspension: Eibach Alignment: (F) Factory spec (R) Factory spec Fender Modifications: (F) None (R) None Rubbing?: None
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
08-09-2011, 07:00 PM | #46 |
Rep 243
Brosef, how much was it to pull the fenders?
JB, Bamboo, every option, 20" Adv.1
08-09-2011, 07:09 PM | #47 |
90
Rep 1,315
ar: 11 E92
Wheels w/ Offsets: Volks TE37SL - (F) (R) 18x10.5 et20 Spacers: None Tires / Miles: Hankook RS3 - (F) (R) 285/35/18; New Tires Suspension: Moton CS with camber plates EDC Setting: none Alignment: (F) -2 (R) -1.6 camber 1/16" toe Fender Modifications: (F) None (R) None Rubbing?: none. |
08-17-2011, 06:01 PM | #48 |
2746
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Are you on Yokohama AD08's?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-17-2011, 07:29 PM | #49 |
42
Rep 788
Mineral White + HRE + Brembo + Eisenmann + Challenge = Perfection |
08-17-2011, 08:14 PM | #50 | |
30
Rep 361
What do you guys think about a 18x10 ET25 front with 285/35/18 and -1.7 camber? If he fits shouldn't that setup fit as well?
08-18-2011, 02:48 AM | #51 |
471
Rep 2,991
car: 11 E93
Wheels w/ Offsets: Volks TE37 - (F) 19x9.5 et22 (R) 19x10.5 et 20 Spacers: None Tires / Miles: Toyo T1R - 265/30r19 285/30r19 Suspension: H&R coilover with Dinan fixed camber plates EDC Setting: none Alignment: (F) -2.4 (R) -2 camber Fender Modifications: (F) None (R) None Rubbing?: None at all. Last edited by kitw; 08-18-2011 at 03:12 AM.. |
08-25-2011, 11:49 AM | #52 |
Rep 210
Added mine to help out those considering A/S tires
'09 E92 Wheels w/ Offsets: Stock 220M Spacers*: 12mm front, 5mm rear Tires/Miles: Michelin Pilot Sport A/S Plus (F) 255/35/19 (R) 275/35/19; New Tires Suspension: Stock EDC Setting: none Alignment: Stock Fender Modifications: (F) None (R) None Rubbing?: none on this setup, previoulsy had 15/12 spacers and the front barely rubbed but the rear rubbed badly on bumps |
08-26-2011, 12:05 AM | #53 | |
90
Rep 1,315
For camber, it's hard to say. You need to feel the suspension and steering feedback to adjust your camber setting though. It depends on what tires you wanna run. I would recommend 285/30/18 for fronts and keep it close to stock over diameters. |
09-17-2011, 01:46 PM | #55 |
77
Rep 1,376
Drives: 1988 M3, 1990 M3, 1998 M3/4
Garage List 1998 BMW M3/4 [10.00]
2011 BMW M3 Sedan [9.28] 1988 BMW M3 [9.40] 1990 BMW M3 [10.00] 2008 BMW 135i - sold [0.00] 2003 BMW M3 - sold [0.00] |
You will rub for sure! There are a few that have issues running the 255/30/20 when lowered. You have to be really careful about increasing the overall diameter over stock on the front. There isn't much clearance with the fender liners.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black 1998 BMW M3 - Alpine White/Mulberry 2011 BMW 328i racecar - LeMans Blue/Black |
10-16-2011, 07:20 PM | #56 |
433
Rep 1,286
Car: 09 E90
Wheels w/ Offsets: RAC RG63 - (F) 19x9 +22, (R) 19x10 +22 Spacers: None Tires / Miles: Bridgestone RE-11 - (F) 255/35/19, (R) 285/35/19; New (300 track miles) Suspension: stock Alignment: (F) Factory spec (R) Factory spec Fender Modifications: (F) None (R) None Rubbing?: None |
10-17-2011, 09:40 AM | #57 |
56
Rep 1,962
Update
Car: 11 E90 Wheels w/ Offsets: OEM ZCP + Spacers = 19x9 et24 / 19x10 et 25 Spacers: F 10 / R - Tires / Miles: 255-35-19/295-30-19 Advan AD08's - New Suspension: KWV3 EDC Setting: None Alignment: Stock Rubbing?: F - Have rubbing at from 1/2-3/4 wheel turned in either direction on the rear side of the fenders. The rubbing isn't severe but annoying. Strangely, I'm not rubbing on full lock. Nothing detrimental to the car. R - Rubs on hard dips on the part where the bumper attaches to the car( same place as everyone else) Can't really hear it no more but it still rubs there. Nothing detrimental to the car.
Peanut Butter Chunky
10-31-2011, 01:16 PM | #59 | |
30
Rep 361
Mine is 305/35/18, which have an overall height of 26.4 in and width of 12.01 in Your proposed setup 305/30/19 would be 26.2 in high and 12.01 in wide So your tires would not be as high as mine, so no risk of upper rubbing. Also PSS have a more rounded edge than my squarish/fatter RA-1s so I think you would be good there too. Wheels would be an 11 inch wide wheel w/ offset of 32 with max stock camber (I would like more, but no rubbing issues either way).
11-03-2011, 11:47 AM | #60 |
20
Rep 157
E90 ZCP '11
TE37sl front 18 x 9.5 et22 rear 18 x 10.5 et25 NT05 265/35 285/35 pins pulled camber LF -1.21 RF -1.28 toe .05 .05 camber LR -2.08 RR -1.51 toe .07 .07 the rears will rub over speed humps on that black plastic nub Last edited by SuitedPair; 11-03-2011 at 11:48 AM.. Reason: sp |
11-03-2011, 12:06 PM | #61 |
187
Rep 1,085
Car: 11 E92 with ZCP
Wheels w/ Offsets: OEM ZCP + Spacers Spacers: F 18 / R -15 Tires / Miles: 255-35-19/275-35-19 Conti ExtremeContact DWS X Suspension: Eibach springs EDC Setting: Normal Alignment: Stock Rubbing?: F - Have rubbing at from 1/2-3/4 wheel turned in either direction on the rear side of the fenders. The rubbing isn't severe but annoying. R - Rubs on medium-to-hard dips - very annoying. Final comments: It's a pain in the ass that this set-up rubs since with the stock 245/265's, it had no rubbing at all with the aggressive spacers. I'm either going to remove the spacers altogether, or pick up some stock 18's and use those with winter tires and keep summer 245/265's with current spacers on for warmer months. Last edited by Jet335i; 11-04-2011 at 07:19 AM.. |
01-01-2012, 06:44 PM | #62 |
DSC Off!
307
Rep 718
Car: 2008 E90
Wheels: OEM gunmetal 18" Spacers: 15mm front, 12.5mm rear Tires / Miles: Michelin PSS - (F) 245/40/18, (R) 265/40/18; New Tires Suspension: OEM Alignment: (F) Factory spec (R) Factory spec Fender Modifications: (F) None (R) None Rubbing?: Slight rubbing in rear at speed over large compressions. No rubbing in front. Trade my new 12.5mm Turner Spacers for your 10mm spacers? |
02-12-2012, 07:52 PM | #64 |
Rep 398
Car: 11" E92 ZCP
Wheels w/ Offsets: ZCP 19" wheels Spacers: Front : 12mm Rear 5mm Tires / Miles: Michelin Pilote Super Sport - (F) 255/35/19, (R) 275/35/19; New Tires Suspension: KW Sleeve over kit- Front : lowest setting Rear : 1 turn from lowest setting EDC Setting: Normal/Sport Alignment: standard setting Fender Modifications: (F) None (R) None Rubbing?: NONE Cheers! Last edited by iDRIFT; 04-29-2012 at 04:44 PM.. |
02-16-2012, 02:04 PM | #65 |
46
Rep 637
Drives: '06S2K,'11EVO,'11Jeep,'13GL450
2008 E90 M3
Square set of 4 ZCP REAR wheels. Front: 19X10 ET 25, 275/30/19 Vredestein Sesanta Rear: 19X10 ET 25, 275/30/19 Vredestein Sesanta Stock alignment and suspension. No rubbing at all.
'06 Honda S2000 #555 TT5
'16 Porsche GT4 Last edited by snowmants; 02-16-2012 at 02:13 PM.. |
02-16-2012, 02:20 PM | #66 |
181
Rep 1,245
Car: 2011 E92 M3
Wheels w/ Offsets: APEX ARC8 - (F) 18x10 +13 (R) 18x10 +20 Spacers: 12mm Front, 5mm Rear Tires / Miles: Hankook RS3 275/35/18 Square Suspension: KW V3 + GC Camber Plates EDC Setting: N/S Alignment: (F) -2.5 (R) -2 Fender Modifications: (F) None (R) None Rubbing?: None |
