11-05-2009, 04:13 PM | #1 |
134
Rep 204
DIY: Brakepad Wear Indicator removal for on track
Race pads often don't come with the cut out for the brakepad Wear Indicator Sensor.
Racers that do some work on their own cars don't need the sensors anywaz...They suck, and the small metal spring that keeps it in to place gets lost or broken all the time! So let remove em'! If you follow this DIY you WON'T get a warnin' on the dash that your brakes need service...ever again! excuse my Iphone picas It takes 10 to 15 min each corner. Tools needed: - Very small screwdriver - Cutting Pliers - Shrink sleeves or some electrical tape. - Soldering unit (Not really needed) Remove your Wheels to get access. Front: New carbon composite brakepad without BWIS cutout (Yes, that's short for: Brake Wear Indicator Sensor ) Background: stock pad. BWIS's These are the sensor wires you'll be removing from your system. To get the cable out, Remove the BWIS from your pad by pulling on it. And follow the line to your Shock. You can push the cable out of the 'clamp'. Now find this box. Open it. Get the cable out of the second clamp. And pop the White (White on my Euro spec car, It's the top one) connector out of the box. Pull the connector apart and open the connector (THAT IS STILL ATTACHED TO THE CAR!), and remove the black clip with a flat head screwdriver. Almost looks like I'm black on the pica, your gonna get dirty with brake dust! Apply quite some force on the two silver looking points with a really small screwdriver. After applying force the internal connectors are somewhat bent and this enables you to pull out the two wires for the top. These wires come out. Out of focus and moved....I'm a natural! But this is how the wires look like. Cut the connector ends and nice rubber thingies off, twist the two wires that you have now stripped, together and if you have some time solder 'em together. Tape up the newly soldered wires or use some heat slink sleeves like i did. Put your new creation back in the box, close it. DONE!! Yes you can do this the easy way, by putting a piece of wire in the connector. But this is nice and it can withstand track use, it's reliable. Good Luck!
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
11-06-2009, 05:01 AM | #2 |
e36s54, e70x5d
151
Rep 1,723
Junior -- you have some great DIY's and your effort is certainly appreciated ....
Thank You ... and as a sign of appreciation --- we (@ m3post) want to get you a gift certificate to a 'mastering the digital camera' class, ... near you --- it would only benefit us. Thanks again |
11-06-2009, 06:31 PM | #3 | |
134
Rep 204
I'm on the West Coast Monday! KLM 601 AMS-LAX -> AA 162 LAX-LAS. I'll take u up on that!
11-06-2009, 06:42 PM | #4 | |
258
Rep 5,012
Hey, what exactly trips those sensors? Didn't see any metal piece, and you supposedly need to replace them if tripped. Do you actually have to replace all that cable? Just curious. |
11-06-2009, 06:50 PM | #5 | |
134
Rep 204
it's because one of these sensors is damaged/activated. You need to replace the entire cable. Or follow my DIY Cheers
09-22-2010, 01:48 PM | #7 |
100
Rep 700
I do not get it. Why can't we just remove the sensor from the pad and zip tie it somewhere on the strut? Maybe I need to see it to understand better.
I apologize for spelling mistakes up front, they are a result of multitasking.
09-22-2010, 02:51 PM | #8 |
15
Rep 751
09-22-2010, 03:01 PM | #9 |
7
Rep 229
09-27-2010, 09:26 PM | #11 |
62
Rep 924
Drives: Ford Falcon Ute, Ducati 1198S
My car has been counting down the kms to brake pad service...Does this remove this altogether or just remove another message saying pads need replacing?
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
09-28-2010, 08:13 PM | #12 |
433
Rep 1,286
No your car will still keep counting down to the next brake service. The wear sensors are really just for when your pads are so far worn that the wear sensor starts getting it's contact grounded out through the rotor. There's probably a DIY somewhere here to reset the brake service indicator.
09-28-2010, 09:58 PM | #13 |
62
Rep 924
Thanks VictorH.
I have researched the procedure for resetting the service intervals, available here: http://www.e90post.com/forums/showthread.php?t=51049 However, for a successful brake wear/service interval reset you must replace the brake wear indicator assembly with a new one or you will get a warning saying the pads must be replaced, regardless of previous pad wear. Does anyone know if the above procedure results in the same signal to the car as you would get when fitting a new brake wear indicator cable?
10-02-2010, 03:37 AM | #14 |
113
Rep 1,319
what if I have a CANBUS II reader. Can I select and delete the brake sensor light with it, if and when it appears? I'll have my sensors zip-tied off also when I get my BBK installed.
03-10-2012, 07:27 PM | #15 |
22
Rep 441
Is this method reversible?
2011 Alpine White/Fox Red 6MT E92 M3 | Active Stage 2 w/Meth | KW Clubsport | OSS | Challenge Front Lip | Vorsteiner Type 2 Rear Diffuser and Bootlid | Brembo | Recaro | Akrapovic Slip-On | Challenge Race+ X-Pipe | Vossen CV3 | OEM 359M | TE37SL
03-10-2012, 07:31 PM | #16 |
11818
Rep 23,187
good to know i just put in ds2500s this week and was wondering about the reset on my idrive for the sensor. as it turned out i needed to go in for something else to the dealership so they just reset my indicator. will do this mod next time though.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
03-26-2012, 06:18 AM | #17 | |
To drift is not a crime
73
Rep 192
04-02-2012, 07:13 PM | #18 |
Monster unit
44
Rep 327
So if you tie the sensors for bbk you'll still get the count down??
MONSTER UNIT M3 E90
GT4 - AKRA EVO - RECARO - AP RACING - KW CLUB-SPORTS - VOLKS |
04-04-2012, 08:16 PM | #19 | |
chris
278
Rep 12,144
i have tied down my brake sensors because i have a bbk installed. but i still get the count down despite the fact that the brake sensors are no longer connected to my brakes.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
04-23-2012, 12:28 AM | #20 |
57
Rep 600
Drives: 2012 E92 SSII ZCP DCT
How to do the rear one? anyone?
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER |
04-28-2012, 08:52 PM | #21 |
44
Rep 310
04-28-2012, 09:48 PM | #22 |
57
Rep 600
We have one in the rear.
