11-28-2023, 09:45 AM | #244 | |
1253
Rep 613
Drives: F87 M2 CS
AA really needs to go back to the drawing board with the design. Some theorize that they just reused the same pipes as the M3/M4, which helps explain the clearance issues. But who knows. Regardless, the exhaust has been enough of an annoyance that I certainly wouldn't buy the axleback again, if I could reverse time. I'd be giving my money to a different brand. Especially because AA was absolutely useless when XPH supposedly reached out to them for a warranty claim.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S |
11-28-2023, 09:50 AM | #245 | |
3102
Rep 3,040
Drives: 2019 M2 Competition
Now all that said, dont take that as me denying yalls concerns or that your experiences aren't real and sorry to hear it. For the warranty issue, I would call Active directly as I have spoken with them a ton and even met all the key folks at Bimmer Invasion Orlando. They are great folks and I struggle to imagine they wouldn't do everything in their power to support you. Just my two cents.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
11-28-2023, 11:25 AM | #246 | |
1253
Rep 613
Drives: F87 M2 CS
And, while I'm sure they are perfectly friendly in person, if they wanted to provide support to help find a way to alleviate my issues, they would have. (exchange for proper fitting parts, partial refund, full return... anything) As I imagine you have, I've installed plenty of exhausts on various cars over the years. The fitment issues and overall experience I've had with this one tops the list as being the absolute worst. Which is quite odd because the EL midpipe fits and performs flawlessly. I do love that piece and would recommend it to others.
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S Last edited by DadVibes; 11-28-2023 at 11:37 AM.. |
11-30-2023, 04:56 AM | #247 |
Boost All the Things
122
Rep 96
How wild. I have the full AA catback w/EL midpipe. The only issue I've had is on the DRIVER'S side. The non-resonated version fit fine, but when I changed to the resonated, I had to dimple the driver's side where the midpipe passes right next to the differential support frame. The axle-back portion has been fine with both.
'21 M2C, HS, MT, EP - AA EL + Axle Back, FMHE, "Enabled"
Past - '09 335i Sport, '11 M3 ZCP Sedan, '11 550i M-Sport Also - '94 F-150 Lightning (mild, mid-mount turbo), '95 F-150 Lightning (big motor, big turbo), '15 Chevy SS Sedan (supercharged) Last edited by FMOS Racing; 11-30-2023 at 05:03 AM.. |
04-22-2024, 09:47 AM | #248 |
137
Rep 132
Hey all, for those of you that have had clearance issues with the resonated setup did anyone try swapping the driver side hanger bracket by the diff to the passenger side and vice versa? I called AA to ask some questions on the axle back exhaust since I already have the AA EL on my car. I spoke with Alan and he indicated that if you use the resonated pipes with the AA EL mid + their axle back that they are now recommending to switch those brackets. Apparently it gives the system enough clearance to prevent rubbing. Did anyone give this a go curiously?
04-24-2024, 07:11 AM | #249 |
122
Rep 96
From a picture earlier in this thread, this is where mine would hit and vibrate. I'm not sure how changing brackets would impact that. Does it make the exhaust hang lower?
Past - '09 335i Sport, '11 M3 ZCP Sedan, '11 550i M-Sport Also - '94 F-150 Lightning (mild, mid-mount turbo), '95 F-150 Lightning (big motor, big turbo), '15 Chevy SS Sedan (supercharged) |
04-24-2024, 11:50 AM | #250 | |
137
Rep 132
Correct, you’d need to swap the drive and passenger side hangers to allow for more clearance, but only for the resonated set up, we haven’t updated the instructions yet because it’s a relatively new solution we found as is the double res connecting pipes that new orders with your same set up would be receiving. I’d assume the forums haven’t mentioned it either since it’s something new. |
04-25-2024, 02:44 PM | #251 |
137
Rep 132
just a quick follow up to all this....
Per Alan at AA they have indeed revised the EL resonated connecting pipes that are used with their exhaust. "...we have revised pipes just for M2C EL’s that are paired with our rear exhaust. It’s now a double res pipe (2 resonators on each pipe) rather than a single res pipe (1 resonator on each side)." |
04-26-2024, 12:13 PM | #252 |
122
Rep 96
That's very interesting. I wonder how it sounds compared to the single-res version?
MSH_136.50 |
04-26-2024, 12:14 PM | #253 |
12
Rep 127
Just got mine installed with the non-resonated pipes and I absolutely love it. Minor drone under 2500 rpm but considering these cars sit at 3k at highway speeds is a non-issue. Sounds way better than the dinan system I previously had IMO.
MSH_136.50 |
04-26-2024, 12:22 PM | #254 |
BimmerPost Supporting Vendor
24415
Rep 191,323
Congrats
05-06-2024, 06:08 PM | #255 |
Total Scrub
36
Rep 27
Rattle or normal on AA exhaust & midpipe?
About a year ago I purchased an M2C with AA EL midpipe and valved rear axle-back exhaust. Love the car and 90% of the time it sounds INCREDIBLE. However, there is a very pronounced rasp, especially on startup and warmup, which is very noticeable, even when the windows are closed.
I've seen folks mention rattle and other potential issues with this setup. Could another owner or someone familiar with this setup listen to the audio and opine on if this is a normal, expected sound for this exhaust? I don't particularly love the rasp, but if it's normal i'll live with it. If it's an unexpected rattle, I'd like to get it fixed. Thanks! https://youtu.be/ft22-iEAscg |
05-07-2024, 09:36 AM | #256 |
Rep 9
I'm surprised I didn't see all these complaints when researching the AA exhaust... it may have caused me to have second thoughts lol.
Anyways, I purchased a used single AA midpipe (non-res) from a fellow forum member and the AA valved exhaust from Mike at x-ph (shoutout for the awesome deal and crazy quick shipping). Installed both a couple weeks ago and have had absolutely zero issues with drone or poor fitment... and the sound is just about perfect with the burbles turned off. |
05-07-2024, 10:42 AM | #257 | |
24415
Rep 191,323
05-07-2024, 07:54 PM | #258 | |
233
Rep 239
2021 BMW M2C / AA / Remus / KW
05-08-2024, 06:43 AM | #259 | |
122
Rep 96
05-09-2024, 12:50 PM | #261 | |
233
Rep 239
If you want to get to the bottom of it, try checking all the connections for leaks or any rubbing. Did you swap out the gasket from the downpipe connection when you replaced the midpipe? If you are on unresonated midpipes, this may contribute as well.
