Bimmerpost
4 Series
Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Front Splitter for G20
      07-11-2019, 06:03 PM   #1
g20beam
g20beam's Avatar
475
Drives: G20 330i M Sport
2019 BMW  [0.00]
Hi, I have been looking everywhere online for a G20 front splitter but it’s been almost half a year since I’ve had the vehicle and still to this day I cannot find a aftermarket front splitter. I know BMW has them but I am not trying to pay over 1K on just a front splitter.
Has anyone purchased a front splitter for this car or seen any aftermarket splitters for this vehicle?
      07-11-2019, 11:25 PM   #2
Brett240
Brett240's Avatar
39
Drives: G20 330i
the M sport front splitter is about 700 USD
https://www.getbmwparts.com/oem-part...nt-51192455832
other than that, AC Schnitzer have one thats not too far away, but not ready yet
https://www.ac-schnitzer.de/en/bmw/3...estouring.html
https://www.ac-schnitzer.de/en/bmw/3...c-package.html
      07-12-2019, 08:06 PM   #3
g20beam
g20beam's Avatar
475
2019 BMW  [0.00]
Thanks for the response. The M Perf one doesn’t come with the carbon splitters that make it look complete, and those are $450 for each of the sides, and together it is around $1800 just for the front splitter set. That’s a lot of money on a piece of plastic that get’s easily scraped since it sticks so low to the ground because of how low the vehicle is. That’s why I’m looking for cheaper aftermarket parts, ones that are quality but at a lower price.
      07-15-2019, 11:49 AM   #4
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
You can get it for 520€ from Leebmann - they usually do not ship overseas but you can may be negotiate the shipment with them
https://www.leebmann24.de/bmw-m-perf...192455832.html
      07-17-2019, 11:26 AM   #5
g20beam
g20beam's Avatar
475
2019 BMW  [0.00]
Thanks, I will take a look.
      07-17-2019, 11:29 AM   #6
g20beam
g20beam's Avatar
475
2019 BMW  [0.00]
There is now a end.cc front lip available and it looks amazing, much better than the M Perf one imo.
https://endcc.jp/products/g20/
      07-17-2019, 11:12 PM   #7
Brett240
Brett240's Avatar
39
Drives: G20 330i
wow they do look nice.
they want a few bucks for them though
      07-18-2019, 11:27 AM   #8
Asterix
Asterix's Avatar
21
definitly nicer , makes the job of the M performance front splitter plus the winglets . What I like in the M front splitter is that it brings more agressive look not at the expense of having a car you can drive only on flat surface. With the M splitter installed I have only 1cm gap left when I enter in my garage . Don't want to be slave of too low or agressive front lip
      07-18-2019, 08:35 PM   #9
Brett240
Brett240's Avatar
39
Drives: G20 330i
can you post a pic of it?
have you lowered yours at all? Im considering a front spoiler though its a daily driver and i dont want the front spoiler to be too much of a hazard.
      07-19-2019, 02:06 AM   #10
Asterix
Asterix's Avatar
21
I had in mind to lower it like my former F30 with ACS springs that are not too agressive - about - 20 mm. But now with the lip in place I will not do it because I'm sure I won't be able to access many places I use to go without putting the lip at risk.
I've attached a pic take in my garage - not very nice because of the light - I will send others from outside later on .
By the way , I've installed it by myself and added few extra metal pieces underneath to get better rigidity of the assembly.
      07-19-2019, 02:10 AM   #11
Asterix
Asterix's Avatar
21
looks like the pic was missing
      07-19-2019, 04:21 AM   #12
Asterix
Asterix's Avatar
21
front clearance 14 cm
      07-19-2019, 03:16 PM   #13
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
Did you stick a mbadge on the splitter? Or did it come like that?
      07-19-2019, 07:48 PM   #14
ashokgadeking
94
Drives: BMW M340i
Did you have to drill any holes into the bumper or were they already there? Does the splitter come with double sided tape?
      07-20-2019, 08:59 AM   #15
Asterix
Asterix's Avatar
21
Yes I did , it is one of those removed from the side.
      07-20-2019, 09:07 AM   #16
Asterix
Asterix's Avatar
21
The lip is delivered without double side tape and is supposed to be fixed with special glue. In fact you get 3 pieces , the main one is the lip the others are soft platic extensions that will support the lip on the sides and close the gaps created between the bumper and the new lip .
Personnally I hate using glue so I've added double side adhesive tape , in the center part of the lip I've used double side tape and drilled holes in the bumper (did not trust the tape enough) - you should make 4 small holes - screws are included in parcel) - the screw in place to maintain the bumper are not properly located to be used for the lip.
As already said I've added also underneath un certain number of metal stripes to make the assembly more rigid - I'm close to german highway and the pressure on the lip at high speed should be quite high.
      11-06-2020, 08:31 PM   #17
rockblock
rockblock's Avatar
57
Drives: 2023 M240 xDrive
any issues with snow...strong enough to plough through wet snow without dislocating?
      11-06-2020, 08:40 PM   #18
rockblock
rockblock's Avatar
57
Anyone installed this type of lip?...I'm interested in how much clearance it would leave me...quite nervous about the snow and whether it will resist to ploughing through wet snow
      03-05-2021, 10:28 AM   #19
gdaddy28
23
Drives: 2021 BMW M340i
Does anyone know if just the m performance splitter can be installed without the CF pieces? It appears that there are 4 holes to secure the splitter under the license plate area plus the beta link but nothing else. Am I missing something?
      08-10-2021, 08:12 PM   #20
Jeffola
Drives: 2021 BMW X3, 2019 Shelby GT350
I just got one of them today. One of the sides was already scratched and just overall not impressed.
      08-10-2021, 09:27 PM   #21
TruthOne
TruthOne's Avatar
1081
Drives: 2021 M340i
Nice but it's $900
g20
