11-21-2023, 01:20 AM | #1 |
iCARMIX
155
Rep 588
F40 3D Design lowering springs designed for the original shock absorbers.
I've encountered a few cases where people wanted to lower their ride without necessarily replacing a perfectly fine suspension system.
You can't go for lowering springs such as the ones from H&R or Eibach, which are good quality, nothing against them, but unless you match them with a Bilstein B8, that's a sure way for the original shock absorbers to get damaged. Enter 3D Design. The F40 M135i in the photos was just upgraded to these springs manufactured in Japan, and can give lowered results of anywhere between 20mm and 30mm depending on the car model. This particular model lowered by 20mm. The final result is a more streamlined look, with a lower center of gravity; An upgrade in both handling and cosmetics. Here's what we got:
Website: https://icarmix.com/
Tags |
3d design, f40 m135i, hong kong, icarmix, lowering springs, suspension |
