Procede V5 11-01 Aggressive maps now available
11-03-2011, 06:59 PM | #45 | |
184
Rep 2,841
11-03-2011, 07:01 PM | #47 | |
65
Rep 1,708
11-03-2011, 07:01 PM | #48 |
I sweat pheromones
203
Rep 2,103
11-03-2011, 07:03 PM | #49 | |
3441
Rep 79,211
As mentioned before the UT and IC values are different then the old maps so right now you just run the appropriate stage for your car. edit- Last edited by Jeff@TopGearSolutions; 11-03-2011 at 07:09 PM.. |
11-03-2011, 07:07 PM | #50 |
1746
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
+1 . The only people who are going to change map 2 settings are those running methanol. For everyone else just select the right stage file and run map 1. I purposely set up so that map 1 is equal to map 2 by default.
11-03-2011, 07:18 PM | #52 |
3441
Rep 79,211
11-03-2011, 07:24 PM | #53 |
83
Rep 2,291
Great, thank you; I'll try them tomorrow!
2jZ + RB26 + 4G63 + LS9 + N54 =
11-03-2011, 07:26 PM | #54 |
3441
Rep 79,211
11-03-2011, 07:28 PM | #55 |
13
Rep 377
ok that somewhat answers my question...i am running pwm meth..i selected stage 3 maps since im fbo, just need to know bout changing map 2 settings
2007 335i Coupe 6AT - Sports Package - Premium Package - Procede V5 Rev 2.5 - Vishnu PWM - Vishnu DCI - Vanguard Exhaust - AR Downpipes - Helix FMIC - 19" Avant Garde M6 Reps - Michelin Pilot Super Sports - Bilstein PSS10 - M3 Suspension Bits - M3 Sway - M3 Strut Brace - GP Thunder -Forge DV -15% Tint - Aero Lip
11-03-2011, 07:32 PM | #56 |
69
Rep 1,943
I think people are getting confuse because theres people talking abt setting for non meth users and meth users. Some say 100%IC both maps, some other 0%IC. I say we separate PWM meth settings and non meth setting into 2 different threads.
To sum it all up. PWM users 0% IC UT 65% everything else Stays the same right
PROCEDE, PWM Vishnu Kit, AR catless DP, BMS DCI, Helix IC, P3 gauge, 25% window tint, mattblack window trim, mattblack roof wrapped. Vorstainer CSL trunk, CF wrapped interior, 18'' Forgestar F14 Matt black, quaife LSD, M3 suspension bits, Mtech front bumper). http://www.youtube.com/watch?v=b8JIB8C8HDA
11-03-2011, 07:33 PM | #57 |
13
Rep 377
read post below yours..you are saying to leave everything alone, but shiv says only people should be changing values are meth users..i am running meth..and been running all the aggressive beta maps prior to this one, and my map 1 was left as default but my map 2 was start boost 65 and ic 0. im just wanting to know with my setup should i be running 65/0 on map 2 or the default 14.9 and 100% ic???
11-03-2011, 07:34 PM | #58 | |
1746
Rep 17,960
Drives: A Lot
Shiv |
11-03-2011, 07:35 PM | #59 | |
3441
Rep 79,211
For methanol users run these settings: -MAP 4 (Progressive methanol), as before, is fully enabled. With these aggressive maps, we recommend a meth/water mixture of at least 75/25. Suggested Start Boost and Ignition Correction settings (for Map2) are 65% and 0% respectively. For everyone else leave the default settings. Sorry for the confusion guys. I dont assume anything even if your signature says what mods you have. I'm conservative (I see guys all the time with mods in their signature and they arent even installed). |
11-03-2011, 07:36 PM | #60 |
13
Rep 377
looks as if im not the only person confused about this...the instructions and read me needs updating again with further clarification on this matter as right now its contradictory
11-03-2011, 07:41 PM | #62 | |
65
Rep 1,708
11-03-2011, 07:42 PM | #63 | |
13
Rep 377
its cool..my signature is accurate lol..i read that part, and assumed i should change it..then i read further and it started something about the scaling change, so wasnt sure about changing it..basically map 1 has different scaling far as start boost at 14.9 and should be left alone..and for meth users map 2 can be set to 65/0..gotcha!!
11-03-2011, 07:42 PM | #64 | |
I sweat pheromones
203
Rep 2,103
11-03-2011, 07:44 PM | #65 | |
1746
Rep 17,960
Drives: A Lot
Shiv |
11-03-2011, 07:44 PM | #66 | |
1746
Rep 17,960
Drives: A Lot
Shiv |
