09-11-2018, 03:56 PM | #1 |
75
Rep 437
Fuel injector replacement, does it needs to be reprogram?
I have replaced one of my fuel injector and now the car drives like crap i have a fuel cut at around 3800rpm when going full throttle...
So my question is; does the new injector needs to be coded/calibrated for the car to run properly and equaly with all other injectors? -MK |
09-12-2018, 10:57 AM | #4 |
75
Rep 437
09-12-2018, 07:32 PM | #6 |
518
Rep 629
Yes, the injector value needs to be input into the dme with a service function in ista-d. The car will run without it though. Why did you replace the injector in the first place?
09-14-2018, 02:50 PM | #7 | |
75
Rep 437
Since these injector are the same on all 3L turbo engine it probably needs to be calibrated for the fuel amount i need on the m4 compared to let say a 335 or an x3 |
09-14-2018, 02:52 PM | #8 |
75
Rep 437
The injector was bad and causing a lot of misfire on cylinder 4 so i have replaced it
09-15-2018, 03:48 PM | #9 | |
587
Rep 897
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
09-15-2018, 09:39 PM | #10 | |
824
Rep 1,584
09-18-2018, 12:19 AM | #11 |
587
Rep 897
It's in ISTA. Just look it up.
Lazymccrazy0.00 |
10-25-2019, 10:09 PM | #12 |
Rep 14
probably a dumb question....
I came across having to replace my injector(s) as well and found out about it needed to be coded in. besides that, I also seen, EU5 and EU6 injectors both said would fit my 320i n20 (FCPeuro).... I've been looking everywhere as to how can I find out which one is for my car... appreciate the help! |
10-26-2019, 11:47 AM | #13 |
BimmerPost Supporting Vendor
8286
Rep 18,861
Drives: BMW
What they're likely referring to is if the index numbers match on the injectors (original and replacement), you can get by without programming.
Java440x4.50 |
10-27-2019, 02:19 PM | #14 | ||
Rep 14
