      02-26-2024, 05:00 PM   #1
Andrew.Sydney.AU
Australia
Drives: 1 series Jan 2019 - Australia
iDrive Upgrade -not happening
I have a 1 series 2019 with drive the latest upgrade (current 03/2023.50 - downloaded 11/2023.50) has been downloaded, but the car is not asking to install it.
I have updated the apps, and restated the idrive no luck.
any one have some smart ideas ??
      02-27-2024, 02:08 AM   #2
Nikysan
Drives: BMW M235i F44
There's a whole list of different reasons including having an old battery which may require a trickle charge overnight.
At the end of the day because I had an F44, it turned out that the old battery was an EFB and I needed an AGM battery to updated. Changed, coded and registered and it updated.
Hedoniste3877.50
      02-27-2024, 05:20 AM   #3
Andrew.Sydney.AU
Australia
thanks
      02-27-2024, 05:48 AM   #4
cjn
99
Drives: 2021 F40 M135iX
I had this problem with a 15-month old car. The update wouldn't start, and the dealer couldn't make it happen either. After two flat battery events, BMW Assist arrived at my home, fitted a new battery, replacing a rather warm one with a bulge in the side, and the update went immediately.
Hedoniste3877.50
      04-05-2024, 04:14 PM   #5
notleks64
notleks64's Avatar
23
Drives: M135i
Hi there. Most likely the battery. Try a trickle charge on your battery. This worked for me. You may also have noticed the start stop. Stopped working 😃
      04-07-2024, 11:36 AM   #6
Stumardy
Stumardy's Avatar
Drives: BMW 118i M Sport
Hi, I have the same problem and noticed on Bimmercode that the battery was at 80%. Is it easy trickle charge the battery? also where is it located in the boot or up front? I have a trickle charger but want to try your suggestion to see if the update will install.
Any advice would be great.
      04-08-2024, 11:25 AM   #7
notleks64
notleks64's Avatar
23
Drives: M135i
Hi there. Apparently your battery need to be around 12.6volts. This will allow the upgrade and the start stop will work. I use the CTEK MXS 5.0 Battery Charger with Automatic Temperature Compensation, Black. It’s a really good charger, I got mines on Amazon.
      04-08-2024, 12:49 PM   #8
Stumardy
Stumardy's Avatar
My stop start works, but to be honest I turn it off as I find the auto box can't really handle it, if you know what I mean. It always rattles when starts back up, but I will charge the battery up to 100% to see if that makes the update install.
      04-08-2024, 01:43 PM   #9
notleks64
notleks64's Avatar
23
Drives: M135i
      04-16-2024, 09:32 AM   #10
Hedoniste
Hedoniste's Avatar
No_Country
3878
Drives: M2 CS | M135i
2020 BMW M2 CS  [10.00]
Same problem… and my BMW app told me last day that the update 11/2023.50 expirated. My car is also on 03.2023.50.
2020 M2 CS DCT
2021 M135i xDrive
ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe
      04-18-2024, 04:36 AM   #11
Z-_Hamza_-Z
Drives: BMW F44
You need to a have battery charge state of 80%. My Bmw 2 series Gc had the same issue after i charged the battery with noco charger and drove for a bit the update came up
Hedoniste3877.50
      04-18-2024, 04:47 PM   #12
Hedoniste
Hedoniste's Avatar
No_Country
3878
Thank you for the tip 👍
2020 M2 CS DCT
2021 M135i xDrive
