Creaking Suspension & Brake question
01-07-2014, 11:27 PM | #1 |
126
Rep 330
I've noticed that my suspension is creaking/squeaking when I go over a speedbump, or cresting the top of a steep ramp, this issue is even more noticeable when the car is cold... any suggestions?
Also, Once I go FBO, will the stock brakes be sufficient? I don't track the car, nore do I drive it like I stole it. My rear brakes are getting replaced when I bring the car in for service, just wondering if I should stick with OEM, or try something different. |
01-11-2014, 04:36 PM | #3 |
11
Rep 269
Drives: 2013 335is
I'm still new to the modding scene, but I've read that the most economical brake upgrade, whether tracking or not, consists of high performance brake pads, better fluids, and potentially some slotted rotors. The big brake kits won't necessarily be worth it unless you are trying to do some intensive tracking. This all depends on how much hp and torque your are tuning to.
Note of caution: the slotted rotors, though they allow for better cooling and help clear the brake dust will eat up your pads quicker and are prone to rust and cracking. RB rotors (which are slotted with holes inside the slots) are supposedly a bit better but cost almost 2x as much and still have been reported to crack under tracking conditions. These may not be immediate issues for you if you aren't tracking, but still something to consider. P.S. Sticky street tires, i.e. non-run flats, would probably help a lot too. Last edited by Patronus86; 01-11-2014 at 04:40 PM.. Reason: added tire factor |
01-12-2014, 04:32 PM | #4 |
126
Rep 330
Thanks for the reply
I'm looking at upgrading to stainless lines, hawk hps pads & stoptech cryo slotted rotoros I'm just not sure if upgrading is necessary, or if the oem brakes will be fine with a FBO car |
01-12-2014, 05:38 PM | #5 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
there is a thread on 1addicts suspension forum that beats the ss brake line thing to death. it convinced me to forget about them.
