      04-10-2024, 07:25 AM   #1
eidam655
Drives: BMW 118i (F40)
118i F40 "Sport" suspension in "Comfort" mode?
Hi,
I drive my 118i (F40) mostly slowly - urban & rural conditions, so I usually drive in Comfort mode. However, I like the stiffer suspension of Sport mode.
Is there any way I can get the stiffer Sport suspension in Comfort?
I'm hoping for a software toggle/setting, not full hardware replacement )
      04-10-2024, 03:22 PM   #2
FooMer
FooMer's Avatar
23
Drives: F40 M135i
It can be done (if I understand your question correctly) with drive modes. The way I go about it is to configure Sport Individual mode with all the settings I want and then every time I start the car I activate this mode. Not the perfect solution, but it is one button press - the same as deactivating the start-stop system.
Sadly there's only one Comfort mode, so there's no configuring this one.
      04-12-2024, 03:37 AM   #3
eidam655
I might try poking around the settings then.
So far my understanding was that the Sport mode also put the engine into Sport, and this is what i'd like to separate - leaner engine (a la Comfort), but stiffer suspension (a la Sport). And IIRC I didn't see such options in there.
      04-12-2024, 04:11 AM   #4
FooMer
FooMer's Avatar
23
Drives: F40 M135i
If you press Sport twice you enable Sport Individual, where you can customize several settings - engine, gearbox, suspension, etc.
You could set the first two to "Comfort" and suspension to "Sport".
      04-18-2024, 06:00 AM   #5
eidam655
Hey FooMer,
Just wanted to say thanks for the tip - I found the settings and have it configured Now if only the car remembered the last used setting, that would then be a 100% experience...
      04-18-2024, 07:34 AM   #6
cjn
99
Drives: 2021 F40 M135iX
Originally Posted by eidam655 View Post
Hey FooMer,
This is quite possible with BimmerCode, even in basic mode.
The option is
Default driving mode
The standard driving mode that is activated when the car is started.
Values:
ADAPTIVE
COMFORT
COMFORT INDIVIDUAL
COMFORT+
ECO PRO
ECO PRO INDIVIDUAL
ECO PRO+
ELECTRIC
ELECTRIC INDIVIDUAL
HYBRID
HYBRID ECO
SPORT
SPORT (Hybrid)
SPORT INDIVIDUAL
SPORT INDIVIDUAL (Hybrid)
Don't get carried away, as most of these do nothing. The properly supported mode options are
1=SPORT
3=SPORT INDIVIDUAL
4=COMFORT
7=ECO PRO
9=ECO PRO INDIVIDUAL
