06-11-2021, 03:18 PM | #1 |
37
Rep 201
Idler Pulley Replacement? Aux Belt broken
Gentlemen,
Last night I got a charging malfunction warning, and the ac stopped blowing cold. I checked the engine bay and can see that the auxillary belt has either fallen off or has shredded. I have seen some reports that the idler tension pulley has gone bad on these cars and has needed to be replaced. I track the car, so maybe it's simply wear and tear. In any case, I am trying to decide to replace it and the belt myself or have the dealer do it. Anyone do this at home? Have any input? Thanks Jason |
06-12-2021, 10:14 PM | #2 |
///M SubDriver
1843
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
This job is a bit more of a PITA on the S55 compared to other cars I have done this job on, but it is very DIY’able. I recently did both belts and changed out the idler pulleys and belt tensioner as well. There are a few good videos on YouTube that show how to do it….
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
06-12-2021, 10:17 PM | #3 | |
1121
Rep 1,316
Good luck with the repair |
Sahbatage503.50 |
06-13-2021, 11:59 AM | #5 |
79
Rep 98
I replaced mine at 80k. It is a PITA to change these belts but doable. You have little space to work with because of the fan. You can drop the fan, but there are more things to remove to get the fan down. Good luck.
Edit: I referenced this thread to get the fan down for more space: VTT Crank Bolt Capture install guide https://f80.bimmerpost.com/forums/sh....php?t=1594892 |
jfritz271120.50 |
06-13-2021, 12:20 PM | #6 | |
1121
Rep 1,316
Anyone have the correct torque specs for the various bolts in his videos? ECS has a kit to replace all this stuff: https://www.ecstuning.com/b-genuine-...1288088632kt1/ |
06-13-2021, 01:47 PM | #7 |
37
Rep 201
I'm going to start removing things and see how tight it is. Would think if I can get my hand on it, should be able to get tools to it. Will follow up. I appreciate the feedback and votes of confidence!
I have an appointment with the dealer, but not until Wed, and I want to start prepping for a track event so I am fearful they'll have it for days on end |
06-13-2021, 07:57 PM | #8 | |
///M SubDriver
1843
Rep 2,787
FWIW, I did my belts, tensioner and idler pulleys at 50k miles using an old school preventative maintenance mentality. Everything actually looked pretty good, too, so I feel confident I am good for at least another 50k miles .
06-13-2021, 10:00 PM | #9 |
37
Rep 201
Damn, it's tight in there. Hard to tell from this pic, but looks like one of the tensioners has gone bad, it appears crooked and out of line with other auxiliary pulleys. Idler pulley appears to be fine. Sucks that the water pump belt has to be removed to replace aux belt.[IMG]undefined[/IMG][IMG]undefined[/IMG]
06-14-2021, 06:18 AM | #10 | |
1121
Rep 1,316
I ordered the Conti belt wear tester and am going to try and see if that tells me anything about status of my belts at around 40K with moderate track use over past few years |
06-14-2021, 12:45 PM | #14 | |
607
Rep 1,001
jfritz271120.50 |
06-19-2021, 04:13 PM | #17 |
///M SubDriver
1843
Rep 2,787
I disconnected the oil cooler lines from the oil filter housing to get better access in there. Just make sure you don’t lose the two o-rings that go on the piping in the oil filter housing piping connection, and use plenty of rags/absorbent materials in there of course…
06-21-2021, 04:15 PM | #18 |
37
Rep 201
Got this thing out over the weekend. Bearing seems to have seized and melted the internals. Getting it out was a bitch. You need a t50 stubby torx socket to get a ratchet on it. I decided to replace the tensioner (idle pulley)as well while I was in there. Wish I would have just leave it be. Getting it out wasn't to hard, but getting the bolt lined up and back in with the new one took a lot of patience. The deflection pulleys are not the same FYI. In many pics they look identical, but the lower one is a little larger in diameter.
SCS55291.00 |
06-21-2021, 07:19 PM | #19 | |
1121
Rep 1,316
06-30-2021, 08:58 AM | #20 |
37
Rep 201
Late reply here. Yes, kept the fan in. It's a conundrum for sure. It would be much easier without the fan in there, but removing it is just as much work. I also left the oil lines in place, but if I were to do it again, I believe I would disconnect and try to tie those out of the way. Good news is, it's done and I took it to Autobahn Country Club this past weekend and everything held up. Pretty satisfying to repair myself, though it wasn't fun
jfritz271120.50 |
06-30-2021, 06:51 PM | #21 | |
1121
Rep 1,316
jmciver Would you mind sharing what needs to be done to disconnect the oil lines for this? Is it just removing the one bolt circled below, then just pulling down on the lines? Can't tell for sure if that bolt is what's securing them or not. Thanks! |
06-30-2021, 07:15 PM | #22 | |
///M SubDriver
1843
Rep 2,787
Technically (according to BMW) you are supposed to replace those o-rings, but I did not and did not have any issues or leaks when I put everything back together (the o-rings looked fine and were not deformed).
jfritz271120.50 |
